shortcuts missing refers to has been changed or moved? Help
11
After uninstalling some uncessary programs like games and other stuff like google chrome (i use firefox and IE) off my computer and then restarting, most of the shortcuts orignal picture icons were repalced with general icons. When i try to open one up it says "Item that this shortcut refers to has been changed or moved".
So, I tried going to properties on all of the shortcuts but Icouldn't access the general tab it says "the name specified in the target box is not valid."
When i try to open some one of the shortcuts , like Microsoft Works, directly throguh "all programs" or the actual folder it says " Windows is searching for MSWorks.exe, to locate the file yourself, click Browse." When i locate the file and try to open it, it just continues to say the same thing.
I have also tried a system restore to the date before i unistalled some programs, but when I tried I got an error message that said system restore failed and now when i try to restore it that date no longer exists so i cant system restore anymore...
The thing I am most worried about is that my the Itunes Music Library Folder which held all had all of the files for my music has now turned into one Notepad File. (I was going to backup all of my music on hard drive right after now i cant:cry:)
Thanks for any help!
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
11
i download and used the lnk and exe options and then restarted and unfortunatley it didnt fix the problem...
btw thanks for the quick reply Shawn
any other suggestions?
richc46
Staff member
20,105
Location
Fairfield County, CT
Welcome
Appears to be a bit of a unique problem. Lets see if you can go back with a System Restore
If it does work, back up your stuff. Then remove one or two programs at a time and if you are still good, make a system restore point. Continue the processs. When you find the program that is the cause of the problem, go back with the System Restore and do not remove that program.
richc46
Staff member
20,105
Location
When you DO see the dates, look at the bottom left. Is there a box to tick, show additional dates?
11
Ok i just opened up System Restore agian, and now it says "No restore points have been created on your system disk" ???? (It just showed a restore point from yesterday about 5 mins ago).
richc46
Staff member
20,105
Location
#8
Sometimes circumstances make a solution to a problem more difficult to diagnose because they mislead. Lets, for the sake of testing, assume that the problem was not caused by the removal of programs. Lets run a full anti virus scan and download and make a full and updated scan with malwarebytes. Your problem, other than the uninstalls, sounds like it can be a malware problem
richc46
Staff member
20,105
Location
#11
Run a full anti virus scan as directed, too. Make sure that the Malwarebytes and anti virus are updated first.
