Solved Shutdown window order
bjam
Dear All,
Am running windows vista enter. 32 bit on my machine.
When i use the turn-off short key (Alt F4), the shutdown window appears and the first option in the drop down list is " Sleep ".
I want to change the order of these commands, like: i want the first option to be LogOff.
Any Help.
Best regards,
Brink
Staff member
mvp
Hello Bjam, and welcome to Vista Forums.
I do not believe that this order can be changed other than what you have your Start Menu power button set to.
If it can help, you could create a Log Off shortcut instead to use.
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
bjam
Hello Brink,
Thanks for clarification, since i couldnt reach a result until i read ur post.
The shortcut idea worked fine, thanks alot .
Best regards,
Brink
Staff member
mvp
You're welcome Bjam. I'm happy to hear it worked for you.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
