Skype sound
geneg
My speakers and mike work fine, except when I go into Skype, then the sound does not work. When I use the test speakers, the green lines move as though the sound is there, but I cannot hear it. The mute is not on. Gene
See Pic. Use pull down to select correct device
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
There were only two options as fr as speakers are concerned. I tried both and neither one worked. When I tested the speakers, the green line moved as though there was a sound, but nothing came through.
Hello. just a thought. Maybe your download of Skype was somehow corrupted. You may want to uninstall and then do a reinstall .
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
