Solved Sleep mode problem
arsehley
ive got a 4gig usb plugged into my pc used as a readyboost because its just lying about so i thought id give it a job to do:D but it keeps waking my computer up when i put it in sleep mode but cant find an option to stop waking the computer up in the device manager unlike the network adapters etc ..
so basicly how do i get it to stop waking my pc from sleep mode:rolleyes:?
    Acer Apire m3201
    AMD Phenom 9150e Quad core processer 1.8ghz
    4gig corsair 800 mhz
    ATI Radeon 4870 512mbs gdr5
    32"
    320gb
    ocz extreme 600 watt
    4.0mbs
First, is your computer really going to sleep or in "prevent idling to sleep mode" or "away mode"?
If your system is really asleep the power button will flash on/off. Otherwise, the screen just shuts off, and enters away mode.
This is common in networked computers that are set to "share media". I had the sleep issue happen on all networked computers; desktop; and (2) notebooks. "allow the computer to sleep" setting must be enabled under the power plan(s).
Put your system to sleep and check the power button. If its not blinking its not in sleep mode, and you will have to adjust the settings under advanced power options for it to enter sleep mode.
If the power buton does blink, then check for devices that are allowed to "wake"
http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
fixed ..... cheers i just changed the plan settings using that link and it seems to of done the trick cheers:geek:
    Acer Apire m3201
    32"
    320gb
    4.0mbs
