sleep mode problem
Suzanna
When I wake my computer from sleep mode I do it by clicking the mouse. Lately, when I try and wake it, it makes all the sounds of waking but I get a dark gray screen. I can see just a tiny strip on top which shows that the page is up and running but it's covered over by a gray screen.
Thank you :D
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
This seems a common fault with your system and it seems to boil down to the Graphics driver
I can not advise you as to which driver you should use to correct the fault however i do believe that if you reduce your screen resolution it can act as a work around until you find a suitable driver or someone else here is able to assist you
You my find dxdiag.exe useful to determine which graphics card you have
type dxdiag into the start search and click the display tab and locate :device :Name
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Antec 900
