Sleep mode problem
Lasser
Hi i got problem whit my sleep mode when I put the pc in sleep mood it dosen't wakeing up,after presing the enter it's rebooting from hibernation.​
Some one can hellp me?
Brink
Staff member
mvp
Re: Sleep mood problem
Hi i got problem whit my sleep mood when I put the pc in sleep mood it dosen't wakeing up,after presing the enter it's rebooting from hibernation.​
Hi Lasser,
Welcome to the forum. :party:
Just to clarify things, it will not wake-up from sleep, but will wake up from hibernation?
If this is the case, you might check your BIOS settings. (See Step Three in tutorial) Look to see if the other steps may apply to you to.
How to Troubleshoot a Vista Sleep Mode Problem and Find a Solution
If not, please post back with more details.
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Lasser
Hi Shawn,tx for the reply,I having this problem since my pc crashed on the same time when I try to put it in hibernation.
-That was some problem with the hardware.
I did try all the troubleshoots,install the update -"kb933872" , "kb936150" for 'sleeping mood' from microsoft nothing, it does not workout! It's going to be nice if you can help me tx.
Brink
Staff member
mvp
Ok Lasser,
We will see if we can track this down together. I have a few questions for you first.
Do you have any external devices connected, like USB key or drive?
Do you have a wireless mouse or keyboard?
What is your BIOS set to, S1 or S3 ?
Is this a laptop or home computer?
(Battey power may play a role if laptop)
What is the make and model of your computer?
(Some OEM's have programs that regulate sleep modes to.)
    Lumia 1520 phone
Lasser
Hi Shawn!I have a external drive, it's plug in but is off,during the hibernation.
About the bios -is set like S1 & S3, I try to put just S1 but the fans still working,so I put back default.
The pc is desktop AMD 4600+,2,41ghz
memory-2000mb:o
Brink
Staff member
mvp
Ok Lasser,
In your Power Options, make sure that your have Hibernation After set to Never under the Sleep listing.
Try it with the external drive unplugged as a test.
    Lumia 1520 phone
Lasser
Hi Shawn.
I did try everything but it doesn't help!
What i think about this problem is ,it's not from Vista!It could be from the bios or it might be some hardware problem.
Another thing-when i try to wake the PC from hibernation, it star for a second and then stopping again,after pressing some key it rebooting from hibernation
What's your advise?
Brink
Staff member
mvp
Lasser,
You might try giving up on using hibernation and use the regular sleep option instead. Sometimes Vista will just not work properly with hibernation with some configurations.
I have my BIOS set for S3 only with regular sleep mode without hibernation.
I also heard of bad video drivers causing problems with sleep modes. You might try checking for a newer version or reinstall them as a test to.
    Lumia 1520 phone
ozsurfer
My Dell Dimension 9200 PC with Vista Ultimate purchased in May 2007 also has a problem recovering from a low-power state (I call it a 'low-power state' because I'm not sure which it is - sleep, hybrid sleep, hibernation, standby, some unknown faulty low-power dysfunctional state, or whatever).
When the machine is set to automatically go into a low-power state (which is listed as being Sleep mode), about half the time it seems to go into a state from which it cannot recover without turning the PC off and then on again.
I do not believe that the low-power state to which I refer is 'Sleep'. When I put the PC into Sleep mode via the Start button, it runs through a set protocol ending with the power button flashing. The PC always recovers rapidly on mouse movement or keyboard button press, and so this must be the correct Sleep mode.
I wondered whether from reading the posts on this thread if the PC was going from Sleep into some other low-power state such as hibernation. However, when it is in this dysfunctional state, the power button remains lit.
Vista seems not be using Hibernation any more as a low-power state (as per the above post where Sleep is described as an improved low-power state with features of the old Standby and Hibernation). That said, it is possible to drill-down into the Power Options and find a reference to Hibernation. Question: in Hibernation, does the PC power button turn off, or does it remain lit?
The dysfunctional power-state that I seem to be getting on my Dell PC seems to be a bad version of Hibernation from which recovery cannot occur other than with turning the PC off. I have all the current Vista updates installed as at 14 October 2007.
Along with this low-power state problem I have had another one in particular with Sleep mode which I have documented in the thread at
http://www.vistax64.com/vista-netwo...-mode-internet-connectivity-issue-solved.html
which was a loss of my ethernet connection to my internet modem-router when coming out of Sleep mode. That has now been solved, but the two problems together have driven me crazy.
Does anyone have a suggestion on how I might solve the this low-power state problem??
