Software Registry Over write Problem
2
Location
Lahore,Pakistan
hi,hope u all are fine and doing great, Plz help me,i want to edit some software registry but my windows vista home premium doest allow me to do that,and it shows "Error Writing new values message", even with the administrator login, i have run regedit file as run as administrator but it doesnt allow me to edit the registry.......
Thanks for your concern, i will highly appreciate your reply......
    HP dv6735en
    C2D 2.0
    2GB
    Nvida 8400 GS
    Altec Lansing
Lorien
Account Suspended
2,212
Location
Laytonsville, Maryland, USA
What is the exact error message - word-for-word? Does it occur after you've changed a value and try to save it or at some earlier point? What exactly are you trying to change (please provide the full path to the entry you're trying to change)? Do you know when this started - I mean, when was the last time you successfully changed the registry? Go somewhere else in the registry (it doesn't matter) and find another registry key and attempt to change it (just add one digit or something small like that) and see if it works. If it gives you the error, then post back. If it works, change it back to the way it was and save that change and post back. I'm trying to determine if the issue is with a particular entry in the registry or with the registry in general. Please tell me the results of the test and provide answers to the questions asked at the beginning.
I also suggest you backup your registry (even given its current condition) using: Back up the registry.
Thanks and good luck!
    1920 x 1200 pixels
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
2
Location
Lahore,Pakistan
Lorien thank u for your concern and advice,i tried and i am able to write other software registries,but not of that one,i cant tell you openly just exprimenting with software register keys,hehehe software dont allow me to over right his files.....
HKEY_LOCAL_MACHINE>Software>
but thanks for your reply......
    HP dv6735en
    C2D 2.0
    2GB
    Nvida 8400 GS
    Altec Lansing
