[Solved] Keyboard Repeat Delay Missing in Win 10?
skeezix
Where is the setting for keyboard delay time?
Keyboard delay time is the time from when a key is depressed and held until the time the cursor repeats the character on the screen.
I am using Win 10 and my keyboard is a Microsoft 4000 Ver. 10.
    Windows Vista SP2
    HP a6400f
    3GB
    HP 19-Inch
    500GB
    Not connected
wither 3
Hi Skeezik-
You've posted in the Vista forum. You probably should post in the Win 10 forum- Windows 10 Help Forums
However, I took a quick look at some help on this in some other blogs and it looks like Win 10 has the same controls as in Vista- Repeat rate and Repeat Delay. In Windows 10, those are in Devices and Printers, Keyboard.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
skeezix
Thank you for replying. I checked those locations but didn't find either the repeat rate or the repeat delay. I'll post in a different forum.
    Windows Vista SP2
    HP a6400f
    3GB
    HP 19-Inch
    500GB
    Not connected
wither 3
Would you be so kind as to let me know the solution?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
skeezix
Sure thing (if there is a solution) ;)
    Windows Vista SP2
    HP a6400f
    3GB
    HP 19-Inch
    500GB
    Not connected
wither 3
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
skeezix
@wither 3:
I found the answer for Windows 10:
Open the Control Panel and click on "Keyboard". A Keyboard Properties window will appear.
Click "Speed". The delay and repeat times can be changed in that tab.
    Windows Vista SP2
    HP a6400f
    3GB
    HP 19-Inch
    500GB
    Not connected
wither 3
Great!
Thanks for the update.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
