Solved Some programs not showing in registry
fertedds
Hi All,
I am very confused as to why when I install some programs like COD4 and 5 and some EA games they don't seem to show in the registry, is this normal surely if there are not in the registry somewhere then they would not function at all?
Thanks,
Wizkid
    ME
    Intel Core 2 Duo 2.40Ghz L2 FSB 1066Mhz
    Gigabyte GA965P DQ6 Rev 1 F11
    Geil PC6400 800Mhz 4GB Dual Channel Ram
    GIGABYTE GTX260
    Creative Sound Blaster XI Gamer Sound Card,
    Seagate 250Gb SATA 11, Samsung 400GB SATA
    Corsair 620W HX Series Modular
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
Hello Wizkid,
In the registry they may appear under the publisher name instead.
Did you mean as shortcuts in the Start Menu instead? If so, the shortcuts for them will most likely be in the Games (Games Explorer) button on the Start Menu instead.
    Logitech MX Master 4
Hello Wizkid,
Hi Brink,
This is a picture of the registry, they show up in program files as the maker of the game but I can't seem to find the maker of the games in the registry some are there but not others.
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
I'm sure it's in the registry somewhere if the game is installed. You might search the registry with Activision, COD4, or the name it has for it in C:\Program Files (x86) to see if it can find the location for it then.
Hi
Thanks for your reply.
This is what happens when I serach for Activision and COD4, it jsut goes to a list of keys and not the folder its self.
Thanks,
Wizkid
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
You'll have to keep clicking the Find Next until it may find the actual Key (folder) and not just a DWORD name or value.
I thought that I would be able to look in the registry and find the folder and not have to type in the maker of the game and find it that way, I have been unable to find the folder by typing it in, does this mean that the registry is corrupt??
Thanks,
Wizkid
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
Did you install from the administrator account? Did you get any errors on the install?
    16GB DDR667
    SAS RAID
Yes this is on an Admin account, there was no errors during the install or after.
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
They are there, you're just looking in the wrong location,
When running Vista (or XP) x64 you will find the registry entries for most (won't say all as some manage to go to the wrong folder) in the Wow6432Node folder.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
Ok thanks for your reply.
I'll look in that folder and let you know,
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
Ok thanks I have found it now, I knew it would be there somewhere. Do you know why vista puts some software in that folder?
Thanks,
Wizkid
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
Same reason there is a Program Files and a Program Files (x86) folder, so you know which installed applications/registry entries are 64 bit or 32 bit. Little more to it than that, but that is pretty much it in its simplest form.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
