Solved SONY VAIO LAPTOP PLL FOUND :) yay
nostaw5
"POW" Ur dead
Power User
HELLO FELLOW (sony) LAPTOP OC-ers. trying to overclock? first u need a pll and ur like WTF is a pll... you go on google and r like wot iz dish ****. you look in your laptop and u CANT FRIGGIN FIND IT... GUESS WOT... I FOUND IT. this tutorial is for u...
RECOMMENDED FOR SONY LAPTOPS
first... sony dont like their laptops being oc-ed so they hid settings in bios and put ur pll somewhere u will least expect it. IM running a sony vaio vgn cr14gn and if you want to oc ur sony READ THIS
1. place the laptop UPSIDE DOWN and the battery must face you... ur not touching any components so dont worry bout the battey ****... NOTE that you MAY take out the MEMORY to see more.
2. OPEN THE CASE which holds the memory as seen in figure 1. HERE 02-05-10_0850.jpg
as you can see the pll is in that gap...
THATS ABOUT IT write it down... i got mine from 1.80 to 2.10 and runs as smooth as a babys bottom :)
ANY QUESTIONS JUST ASK
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    Thomson A/B/G/N Router
    LiteON CD/DVD Player
    GAME PERFORMANCE:
    Battlefield 3: 41 FPS High 1x AA @ 1280x720
    Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080
    Counter Strike Source (and other Valve games):
    300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
nostaw5
"POW" Ur dead
Power User
oh now i have it up at 2.6
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    GAME PERFORMANCE:
