Sound from headphones but not internal speakers
Very strange...I get sound when headphones are plugged in, but when they are not, no sound comes from the built-in computer speakers. I have had my computer for about 4 months, and the speakers worked previously; this just started within the last couple days. Any ideas?
    HP Pavilion dv5-1125nr Entertainment Notebook
kavita
CCNA
Vista Pro
    Intel Dual Core 3 GHz
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
Martee
Vista Die-Hard
Hello Andejame,
Please check the following, Right click the speaker icon on the taskbar and choose the Playback Devices, the Sound window will open like this.
Check whether the speaker is working or not, click it, then click Properties, the next window will open
Make sure the Device Usage is Enabled at the bottom of the window, next click Levels tab at this window
In the Levels window make sure the PC Speaker level is set all the way to the right and the speaker is on
Hope it's helpful.
Cheers...
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
