sp2 and updating ie 9
I can't get this wretched machine to download SP2. I used FixIt to gain some ground. After running FixIt, the install of SP2 started but now it only goes to 50% installation and cites Error code 80070490. Without installing SP2, I can't update to IE 9 and therefore can't see some websites properly etc etc etc. It's making my life miserable. Someone please help!
Patonb
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Brink
Staff member
mvp
Hello elittleone, and welcome to Vista Forums.
For that error number, you might see if the MS link below may be able to help. :)
Windows Update error 80070490
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Brink
Staff member
mvp
If you have a restore point dated before all this started available, you could also try a system restore using that restore point to hopefully fix it.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
The SP2 has been failing to install since 7/2011, but I never realized that it was the reason why I couldn't update IE.
The Hotfix worked eventually. But the SP2 still doesn't install. Now in the Windows Update it runs through the full green bar, but still says install failed. I'm just going to keep running the standalone SP2 until someone comes up with something that works for me or it magically completes itself too.
Brink
Staff member
mvp
#8
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Option Two didn't work. According to the advice from Windows Help, if KB947821 doesn't work I should reboot the Windows CD and repair Windows. Problem is, I don't have the Windows Vista CD.
