Solved Spacebar not working
keslap
I have a problem with the Spacebar not working on my Toshiba satellite Pro P200 notebook (NumLock +Alt 032 doesn't work either), although I can use the on-screen keyboard spacebar.
I have uninstalled & reinstalled the keyboard via Device manager but still no spacebar.
Is there anything else I could try, please?
K
    Toshiba Satellite Pro P200
Dwarf
The Contemplator
Hi keslap and welcome to Vista Forums :party:
I take it that you have used the OSK to make your post. Have you tried an alternative USB keyboard?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
lemur
Boot up with Linux or another LIVE CD (doesn't install on hard drive). If the problem persists, then your spacebar is broken. Could also use Bart PE.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
keslap
Dwarf said;
I'm posting from another PC. Unfortunately, I do not have a USB keyboard, but I will try to borrow one next week.
I'm unfamiliar with Bart PE. I'll investigate Linux or similar. Thank you for the suggestion.
K
keslap
I thought I'd update you...
I found a website which showed step-by-step instructions & pictures for removing the laptop keyboard. Following these, I took out the keyboard, removed the spacebar key and thoroughly cleaned under the silicon layer using an isopropyl/water mix. I then left it to dry for a day and put it back.
I have just switched on again and, voila! My Spacebar is working again - yippee. There must have been something preventing contact.
Thank you for your help. Hopefully, the problem won't re-occur.
K :D
