Start Menu - Small or Large Icons
How to Display Small or Large Icons in the Vista Start Menu
This will show you how to have small or large icons displayed in the normal or classic Start menu in Vista.
EXAMPLE: Default Large Icons in the Normal and Classic Start Menu
EXAMPLE: Small Icons in the Normal and Classic Start Menu
OPTION ONE
For in the Normal Start Menu
1. Open the Customize Start Menu window.​
2. To Display Small Icons
A) Uncheck the Use large icons box. (See screenshot below step 4)​
B) Go to step 4.​
3. To Display Large Icons
A) Check the Use large icons box. (See screenshot below)​
4. Click on OK.​
5. Click on OK in the Taskbar and Start Menu Properties window.​
OPTION TWO
For in the Classic Start Menu
1. Open the Classic Start Menu Customize Start Menu window.​
A) Check the Show small icons in the Start menu box. (See screenshot below step 4)​
B) Go to step 4.​
A) Uncheck the Show small icons in the Start menu box. (See screenshot below)​
4. Click on OK.​
5. Click on OK in Taskbar and Start Menu Properties window.​
