Start up error: Winpeshl.exe .... CFGMGR32.dll was not found
wtfvista
:mad:
I have no idea whats going on, come to my computer i try to start it up and it says "Winpeshl.exe - unable to locate component This application has failed to start because CFGMGR32.dll was not found. Re-installing the application may fix this problem.
can anyone let me know what that program is? this one : CFGMGR32.dll :confused:
Need all the help i can get... thanks.
bruce2
Vista Pro
Hi wtfvista, welcome to the board.
You may try repair first by booting from the Vista disk then select repair and let it do its work. If it didn't fix it then try reinstall.
Hope this helps.
Bruce
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
delphin
Eager to learn
Vista Pro
:mad:
That is windows configuration manager service dll.
Try this,
Go to command prombt by typing cmd in run, a black window will open, In that window type regsvr32(space)cfgmgr32.dll and press enter.
Let me know the result :)
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    100 mbps(office lan)
lance711
Hi there,
I seem to be having the same problem, the program I am unable to open (due to the same error) is sp6i386.exe, as well as sp6patch_i386.exe
I did what you said by running cmd and then regsvr cfgmgr32.dll and the results came out like this:
cfgmgr32.dll was loaded, but the DllRegisterServer entry point was not found.
This file can not be registered.
Pls reply ASAP, trying to fix an annoying bluescreen bug (0XF89A6590, 0X00000002, 0X00000001, 0X804D9F6C)
Thanks,
Lux
