Start Up
darkness69
Hello, I have a home built comp with 2 AMD FX-64 dual core cpu's with 2 nvidia 8600 GTS graphics cards. My problem is this eveytime i shut down my system i get an error message that tells me that the \Boot\BCD file is missing and gives me the following error code 0xc000000f. So i proceed to start the Vista disk to repair a drive. Sometime during the loading of the files I get and error message saying that windows can not communicate with an I/O device and get the following error code 0x00000e9. This is very frustrating and just wondering if anyone else has had the same problem.
0x00000e9 may be an Installation error
Are you runing multiple O/S's?, or recently removed a dual boot config? seems like you may have overwrote/corrupted the Boot config, You will have to rebuild the BCD for your Primary OS
You will need to boot in to the recovery enviroment off your disk, Use the BOOTREC.exe TOOL and rebuild, I would also do a system file check, and atribute check.
http://www.vistax64.com/tutorials/163304-dual-boot-using-free-partitioning-software.html (see BOOTREC.exe)
run sfc /scannow
run defrag c: -w
run a full disk check
Run an online NOD32/Norton/Kaspersky malware check
Run a Memory Diagnostic (type mem in start search to access Memory Diagnostic)
Antivirus Scanners & Internet Security Tools
2. Run a System File Check to check the system for integrity violations
note- follow this tutorial- but instead of the defrag command, use sfc /scannow then run the defrag command as instructed in the tutorial
How To Make Vista more responsive and faster
3. Check your HDD that Windows is on for Attribute Corruption. (step 2)
(see above tutorial)
note-Failure of the scans/corruption reports that cannot be fixed will require restore/reinstall
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
It does sound like a boot sector problem. I personally suggest EasyBCD for fixing boot sector issues. It has a very intuitive interface and works with all major OS's.
    HP dv5-1120ej Notebook PC
    Intel Dual 2.16GHz
    NVidia GeForce 9200M GS, 256MB
    320GB internal, 320GB external, 1TB external to come (big download library XD)
    Fast enough
    Firefox, Foobar, and AutoHotkey! Go open source!
