Yes... I'm sorry if i didnt make myself clear. By halfway through a upgrade i mean,..... haha.... let's start at the start. Started with a Vista H.P.x64...upgraded to Win7 H.P.x64 with a upgrade disc from Toshiba. Messed my system up so started the system recovery partition with the intention to start there and upgrade again. When the partition was finished enough to start "seeing" Windows again... I started getting error messages. I figured no big deal. I'll be upgrading like NOW.Using the Toshiba upgrade assistant ,(it deletes things that does not work with Win7 and downloads things that do, drivers etc. plus a LOT of bloatware!), all seemed to be going well until it was time to insert the upgrade disc itself. At that time , my machine would not read the disc. (Why i said "halfway" through). I have done everything i could think of to check the drive, device manager says it is working, also says all drivers are up to date. I even deleted the drivers so windows could reinstall them on a reboot. Cleaned it, went through disc management etc. No joy.
Anyway...... after cussing
, i rebooted for the last time and......... my goodness the things that were bad/wrong/ error messages. Have ran the sfc/scannow multiple times. It's repaired most of the things by now, still getting system/program/application crashes. Still no optical drive. Have repaired some things myself and the sfc/scannow has fixed more. The thing is I think I've somehow corrupted the recovery partition files and as stated earlier have lost my recovery disc's. The System Image i DO have is from Win7 and Vista won't recognize it at all. I do have my machine back into a .... halfway ...stable condition but with still random crashes/failures etc.
You say you might need a cbs log? My goodness that thing must be 1000 pages long?!
could i post just some of it.... or would you need it all?
Thank you for any help/advice you can give.
