Stupid Man Needs Help Reverting to Vista
tontonz
Okay, so it turns out I'm not that bright.
After years of using Vista64 i decided I'd make the move to W10 and, according to the specs and all I'd read my system could handle it. So I bought a copy of the new OS, did a backup of my C drive just in case and went ahead with the installation.
As it turns out my system - in particular my motherboard - cant handle it. My audio is full of crackling and pops and as I work in sound recording this cannot stand. SO! I'm going back to Vista where i didnt have this issue - at least till i can afford to upgrade the whole system.
MY QUESTION - W10 saved my Vista setup as under the windows.old moniker. Can i revert to my last setup using that? What if I had that and a full backup of that drive? OR do i have to do a clean install?
PLUS - is it possible to retrieve my Vista product code from somewhere in my system? I still have my installation disk but i cant, for the life of me, find the serial. I can't find NTUSER.DAT anywhere in the windows.old folder.
Many thanks!
    Processor Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz, 2
    Gigabyte, EP43-DS3L
    4.00 GB
    NVIDIA GeForce 9600 GT
    Presonus Firepod
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
tontonz
    Gigabyte, EP43-DS3L
    4.00 GB
    Presonus Firepod
Brink
Staff member
mvp
If you created a system image of your Vista installation, then you could restore it and have it activated afterwards.
If you're computer came with Vista preinstalled, then you could check to see if you may have a COA sticker on the computer with the product key still on it. Back of PC case, bottom of laptop, or under battery of laptop.
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
tontonz
No, i bought Vista separately from the system. Ive got the CD but I've misplaced the case which had the product key on it. By rights I should be able to use something like Produkey or Jellybean to dig the old key out of Windows.old but all the system files that were supposed to have been stored in the folder were disappeared when I installed 10. And that was only four days ago so the ten day limit hasnt kicked in.
I did create a complete backup of the whole C drive so im hoping if i do a clean install - which it appears I'll have to do - then i can use that to get me back to work
Thanks Brink. If you have any more suggestions please let me know.
Cheers
    Gigabyte, EP43-DS3L
    4.00 GB
    Presonus Firepod
tontonz
Good news! Just found the old cd case lurking in a drawer!
    Gigabyte, EP43-DS3L
    4.00 GB
    Presonus Firepod
Brink
Staff member
mvp
Great news. Please let us know how it went.
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
tontonz
Well, I'm back in Vistatown. Fortunately I had a copy of SP2 to get her up to date. I ran the backup and while all my folders are there none of the data is in them - in particular the program files folders and system folders. I'm assuming W10 swallowed all that on install though I dont know why the backup didnt save them as such.
Now it's back to reinstalling every program and plugin i need to get back to work.
Thanks so much for giving me a hand Brink. Youre a good guy.
    Gigabyte, EP43-DS3L
    4.00 GB
    Presonus Firepod
Brink
Staff member
mvp
I hope it goes smoothly.
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
