Switch to Ubuntu?
Someone can also boot the ubuntu live cd as root and access your files, too.
What do you mean? I know root is pretty much admin, but if I was using ubuntu without the cd how could someone boot with the live cd to access my files? Sorry, I'm still trying to grasp how linux works lol
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
The live cd is based on root user, so you should be able to mount the hard disk and peruse some files. I haven't used Ubuntu in a while, but that should be it. Check out Ubuntu forums if you want more info.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
But wouldn't a person need physical access to the machine? I'm not using Ubuntu anymore, the sound drivers installed in Ubuntu caused conflict when I was in Vista so I just uninstalled it.
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
Yes, that's why you would remove the cd drive, disable the USB ports, and probably lock up the machine. Sound conflicts? Do you have an external sound card or Realtek Audio?
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
The sound card is Intel, so integrated, and the driver is IDT...
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
Maybe you can try Ubuntu 9.10.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
I don't think there is a 9.10... I just looked on the ubuntu page and the only downloads are 9.04 and 8.04...
Either way, Also I just seen I have the 32 bit version on an iso and I was using it on my 64 bit machine. Wow...
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
9.10 is coming round about next month. Get the AMD64 .iso if your cpu is 64-bit which it most likely is.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Hmm, yeah I might, I'm about to download the x64 version of 9.04, I can't believe I didn't see that option. Another thing weird about Linux is that when you install a program, you dont get a desktop icon, you have to go in and make it show in the drop down menu off apps then drag it off, or run it in terminal. Kind of a hard hit compared to just a point click interface like Apple and Windows.. But its a big trade off, and most of all its free. I know for sure I'll be installed Ubuntu on the desktop I'm planning on building and using it as my file server.
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
You can also right click and select new shortcut and type the command with a picture.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
See I didn't know that, I didnt exactly use it that long to figure much out..
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
i use pen-drive ubuntu (xubuntu) im guessing its a lighter version of ubuntu. It take a little more work but its worth it, i like it, its good if you dont want to dual boot or worry about messing up you currently installed OS
    HP DV4z-1000
    AMD Athlon X2 Dual Core QL-60
    3 GB
    ATI Radeon HD3200
    IDT HD Audio
Re: Ubuntu compatible apps
hmm wait at the start of the thread, you guys were talking about terminals and that is like a command prompt, right? and you download programs thru that? i thought exe files were compatible
let me rephrase that. can you just download an executable file from a browser? does ubuntu work with windows programs?
    Acer 5735z Laptop
    2.0 ghz intel pentium dual-core processor t4200 800mhz fsb
    Acer CathedralPeak Rev
    4gb
    Integrated Intel Graphics Media Accelerator 4500
    Realtek
    15.6" HD CineCrystal LCD
    1366x768
    160gb stock drive. ATA
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
Hello all,
So I'm curious, how many of you dual boot, or triple boot with Ubuntu? If so, how do you like Ubuntu? Reliable? Fast? Easy to use? I'm thinking about formatting my drive and using Ubuntu instead of Vista but I'm still barely learning Vista's tricks so I'm really torn about that decision. I guess I just need know the facts and user opinion before I really make the switch. I'm actually posting this from the "Live CD" and I'm using the try Ubuntu with no changes to your machine. Plus a lot of the cracking and really neat monitoring programs are linux only so it kind of sucks since I really want to get into that. NO I don't want to hack into other peoples machines to steal stuff, I just would like to learn how it's done so my system isn't open for compromise. So should I make the dive or not?
Thanks guys :)
I run Ubuntu on a separate pc. Extremely reliable. I've worked with Solaris (UNIX), Gentoo, Slackware, OpenSUSE0. Ubuntu is just fine for a reliable workstation.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
For the amount of time I used it, it was great. Customizable, fast, somewhat easy once the learning curve of the terminal is over lol. Also, the interface is nice andeasy on the eyes
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
Ubuntu, like all linux distros, is a different operating system.
Linux has ftp and browser capability.
An X-Window is a shell, not exacly like the dos command thing. Well, you can do more with the linux/Unix version, must more.
An X-Window can be used as a terminal window. Or run programs from.
KDE is a gui interface for use with linux.
You can do anything with linux you can do with Windows. Unix was around before Windows and linux. To some it may be 'old fashioned' but it works and works rather well.
I had a linux computer for several years, but it was packed away until I got my new apartment. I can connect to the internet, use any of several browsers, word processors, etc. designed to run on linux.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
just downloaded myself a new version of ubuntu.... ubuntu studio! so far it looks very good :D
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
Executables (.exe files) are not compatible with Linux. It uses a different shell, therefore executables use different code, as does Mac OS (I believe they use .app's or something). There is a very popular "emulator" called WINE which is not actually an emulator (WINE = Wine Is Not an Emulator). I believe that is what most people use to run Windows-environment (or other environment) tools on a Linux system. Though most tools found in other environments can be found in Linux too. It wouldn't be a distributable OS without the solutions you can get on other OS's.
    HP dv5-1120ej Notebook PC
    Intel Dual 2.16GHz
    NVidia GeForce 9200M GS, 256MB
    320GB internal, 320GB external, 1TB external to come (big download library XD)
    Fast enough
    Firefox, Foobar, and AutoHotkey! Go open source!
I installed wine when I had was using ubuntu, its actually pretty neat. I never got a chance to install anything for it but it came with Notepad. When I ran it, it had a windows 2000 theme to the window so everything looked like MS but it wasn't, useful tool.
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
I ran a remote desktop software using Wine on UBUNTU. Worked flawlessly.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
