Symantec AV Corp 10.2 Autoprotect gets disabled by itself
daq
Hi, I have Symantec Corp AV 10.2. It should work fine for Vista x64, and it does for some time, but then Auto protect gets disabled and I can't turn it back on unless I restart. Then it works for some time again and again turns off.:mad:
Anyone had a similar issue?
If I try to re-enable it, I get the UAC prompt, then tray icon changes to enabled for a second and switches back to disabled.
System log has absolutely nothing about autoprotect shutting down, but does have other messages from the AV. I don't know where else to look.
Any suggestions welcome!
Asky
Here to Help
hey daq,
See Here
Is your problem similiar?
If yes then i guess its the Virus that is causing SAV Autoprotect to get Disabled.See if you can get the Virus removed using a Portable AV(one which runs on a USB Thumbdrive).
I've myself used SAV 10.2 on Vista X64 for a while before i switched to kaspersky , so it does work properly on Vista X64.
    Intel
    Nvidia 9650M GT
    Asus N80VN-X1 Laptop
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
daq
Thanks for reply.
My problem was a lot less serious thankfully. Windows Defender just wasn't disabled properly by SAV, I had to disable it manually from Admin Tools --> Services. Now everything is smooth, no more unexpected shutdowns of SAV.
Asky
Here to Help
Glad it worked out for you mate.
Thanks for Letting us know
    Intel
    Nvidia 9650M GT
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
