syntax error in command prompt?
kiazand
Can someone fix this for me i dont really knw what this is saying when i put that command in. I wanted to do the command where it turns of the spikes while gaming and for some reason this is the error its showing. I think the statement C:\USERS\KOS>C:\Windows\System32\cmd.exe /k netsh wlan set autoconfig enabled=ye
s interface=Wireless Network Connection
juss needs some corrections juss dont knw what. Plz help thnx
Microsoft(R) Windows DOS
(C)Copyright Microsoft Corp 1990-2001.
One or more parameters for the command are not correct or missing.
Usage: set autoconfig [enabled=]yes|no [interface=]<string>
Parameters:
Tag Value
enabled - Set auto configuration logic to enabled or disabled.
interface - Name of the interface for which the setting has to be
changed.
Remarks:
Enable or disable the auto configuration logic on an interface. If it is,
disabled then Windows will not connect to any wireless network
automatically from the specified interface.
Both parameters are required.
Examples:
set autoconfig enabled=yes interface="Wireless Network Connection"
C:\Users\kos>
archie123
I Tunes hates Me
i didnt know there was a command that worked ive been using Vista anti lag for gaming , can you give me a link to this info so i can have a look please :)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
archie123
I Tunes hates Me
thanks :) im alittle confused though , i know that vista anti lag stops all lag spikes , it seems though that he still gets the odd one so uses wlan optimiser too?
Just a very small update.. For grins, I decided to add the little WLAN Optimizer program in addition to my update above and it seems to add a little bit more "effectiveness" on my heavy wireless gaming usage. Another small program called Ping Tester, really helps me see the "smaller spikes". It can be ran on a continual loop and comes in very handy when checking your response times (in milliseconds). If you google WLAN Optimizer and Ping Tester, you should easily be able to find those little programs.. I've included a few screen shots below:
why not JUST run WLAN optimiser or VAL? , they work , i know they do , it seems a waste of time trying his workaround if its not 100% "effective" and ending ip running a 3rd party app anyway
ill give it a go tomorrow see how it works out
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
archie123
I Tunes hates Me
oh and as for your command line
C:\USERS\KOS>C:\Windows\System32\cmd.exe /k netsh wlan set autoconfig enabled=yes interface=Wireless Network Connection
the bit in bold^^^^^ is that the actual name of your connection? did you check it?
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
kiazand
i tried running the antilag program and majority of the spikes went away but i styll get some which cause me to lag in games. I will try the optamizer and see which one works better.
The name of the the connection is actually dlink but when i put that it says no such wlan exists so when i put the wireless connection (written besdie dlink in netwrk sharing centre) it gives me something buh there is that syntax error ...:huh:
usasma
Old and cranky
use:
netsh wlan show all
This will show all WLAN connections so you can get the correct name. I don't have wireless here, so I can't give a better example. If you can't locate the name from that, post a screenshot of the output so we can find the name.
