System config help
Hi
I was wondering if there was things i can do to increase the overall performance of my laptop
to make it as game worthy as possible (if at all possible (for SKYRIM!)).
Specs
Toshiba
^Notebook
^Satellite
^P300 series .
Processor:Intel Core Duo CPU P7450 @2.13ghz
Video Card:ATI Mobility Radeon HD 3650
^Dedicated Memory: 512mb
^Approx Total memory: 1770mb
Ram:4gb
HDD Space: 278gb out of 361gb
Direct X version:11
Basically i would like to find away to at least play games on a decent graphic's setting and for it to run smoothly at the same time
any and all help would be very much appreciated
Well your systems meet the minimum requirements. Keep in mind that laptops aren't usually designed for high performance without sacrificing size and battery life. Also although your processor maybe 2.13 ghz it might be under-clocked.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
