System Configuration / Startup
Bare Foot Kid
R.I.P. August 13th 2014
Hi all,
Now I'm wondering if some of these apps./progs. that
I know that I have uninstalled can be removed from this list?
And if so how?
Thanks to all who may reply!
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Hi all,
And if so how?
Later :shock: Ted
Try expanding the "Startup Item" and "Command" columns to make them a little more visible, and post another screenshot.
But from what I CAN see, I'll disable the following:
  • OsdMaestro - Without more details, I'm guessing that this provides some kind of "On Screen Display" for media devices? Un this functionality is desired, then this item can also be disabled.
  • RegistrySmart - Sounds like some type of registry cleaner and/or optimizer. These things are snake oil, and do more harm than good.
  • Java(TM) Pl... - I've encountered very few websites these days that require JAVA, so this entry is also redundant, unless for some reason you actually need it.
  • SweetIM - This is you Instant Messenger utility, isn't it? Unless you actually use it, you can get rid of it too.
  • SnapFish Me... - I'm also guessing that this might be an Instant Messenger utility - Why do you need two? And unless you're actually using it, you can disable it from startup. Is this perhaps not "Snapfish Memories"? This belongs to HP. Disable this unless you actually need the utility.
  • Microsoft Of... - This is "Microsoft Office Startup", correct? I've disabled this particular entry every time I've installed Office on more computer than I can remember, and Office has never given any problems. It work fine without this entry.
I'll post back more details on the remaining entries once I can see them more clearly.
Also, go to the Service tabs, hide all Microsoft Services, expand the column to make them more visible, then post a screenshot of that too.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
Hi Ted,
In the Location area, under the Startup tab, you will see where the startup program is listed in the registry. Go to that location in the registry and you will see the Startup Item listed in the right pane of the registry under Name. You can then right click on the Name and click Delete to get rid of it in System Configuration.
    Logitech MX Master 4
Thanks guys
Brink it seems that now that I have uninstalled them,
now when I go to the registry location they are no longer
listed, to be deleted. If this leaves me with the only option
to reinstall> delete> uninstall, I don't know if it's worth all
that trouble. I may just "live" with it. Lessons learned. :(
Thank you for your help.
Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Ted,
When you uninstalled these programs, did you use their uninstall option in Programs and Features in the Control Panel?
Hey Brink
Hi buddy
Yes I did. But I figured it out all by myself. :D I'm proud of myself !!! After I went to work today I started to think that if I
enabled them at startup and then went to the registry location
and then deleted them they would go away. It worked !!! COOL
But I do thank you for all your help, without you I wouldn't have
known where to start in the first place.
Thank you Shawn
Later Ted
P.S. Cool sig.
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Ted, I'm glad to hear that you sorted your problem out. Thank you for posting your results.
It's always good to hear back about the successes from those we've helped.
Glad to be of service.
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
Great job there Shawn & Peter. I tried to use the reputation tool, but it said, I had to "spread it around" some more ;)
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main 500 GB USB External 160 GB USB External 2TB USB External
    DSL 3MB
Hi .Joe
You can help mine... he he :shock:
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Hey dzomlija
Sorry to hear about your rig.
Hope it gets resolved real soon.
Later Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
I don't know who just pumped my rep.
THANK YOU :D
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
