System doesn't recognize graphics card
Thunck
First time post, so thanks in advance for any advice.
Here's the problem. My GeForce 9800 GTX is no longer recognized by my computer. As a result it doesn't recognize my monitor specifics either. When I look under Device Manager it doesn't have a listing for display adapters at all. There is a new entry under "Other devices" labeled "Video Controller (VGA Compatible)". When I reboot or "scan for new hardware" it trys to download drivers but fails. When I try to manually update the driver I get a message:
"Windows found driver software for your device but encountered an error while attempting to install it.
NVIDIA GeForce 9800 GTX/9800 GTX+
The system cannot find the filed specified."
I've tried everything including updating my BIOS, updating my mainboard drivers, downloading current WQHL certified graphics drivers, uninstalling any and all drivers related to NVIDIA, etc with no luck. I have a feeling there is something simple that I'm not doing but I have no idea what it is. Any help? I can't play any games because the system "Failed to find a suitable display device. Exiting program."
    Intel Core 2 CPU [email protected]
    nForce 680i SLI
    GeForce 9800 GTX
stoneys-nutz
Gamerholic
Hello Thunck,
Did it just stop suddenly or has it been playing up for a while ?, if you have another card can you try that or try re-seating your card, and also check to see if it is getting power, i had a problem like this and i removed the power lead from the PSU for about 5 min's, then re-connected it and it worked, dont ask me why but it did. Good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
fadedrs
Lost in my own World
Power User
did you try to re-seat your video card?
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
stoneys-nutz
Gamerholic
:roflmao:fadedrs, read my post again.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Crispy2007
64 |3!T G33|<
Get some surcit board cleaner spray it on and it will work fine.
    Intel Core 2 Quad Q6600 (G0 Kentsfield) LGA775 (FC-LGA6)
    GIGABYTE GA-EP35C-DS3R (Rev. 2.1)
    Corsair TW3X4G1333C9A 4GB PC-10600 (2x XMS3 2GB)
    ASUS nVIDIA GeForce 8800 GT (G92GT/D8P)
    Creative SoundBlaster Audigy 2 ZS/RealTek ALC885/889A/890
    ChiMei CMV CT-730D 17inch (LCD Monitor)
    1280-1024 60Hertz (Ture Colour 32bit)
    Barracuda 7200.10 SATA 3.0Gb/s 160-GB Hard Drive ST3160815AS (RAID0)
    SUPER FLOWER 500watt Plug in Leads 24pin ATX BLACK MODEL
    Thermaltake Shark (VA7000SWA ATX) Full Tower
    Front 120mm fan (1400 RPM) /Rear 120mm (1400 RPM) blue LED
    Cyber Snipa Stinger Laser Gameing Mouse (400-3200Dpi)
    Labtec Media Desktop Y-SAD65
    Telstra BigPond Elite Liberty Cable 17Mbps/256kbps
fadedrs
Power User
sorry stoneys-nutz must have missed that when i read it.:eek:
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
stoneys-nutz
Gamerholic
LOL, Im glad im not the only one to do it then.;)
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
JimJoe
Sounds like deja vu.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
stoneys-nutz
Gamerholic
:roflmao:Yea, we all do it dont we ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Thunck
I was getting random BSOD crashes every few days that I thought were graphics driver related but a reset usually worked. It was just recently that it crashed and when I reset it all of a sudden didn't show up in my device manager. I haven't tried to reseat the card yet. I'll give it a go when I get home from work. I do have my old 8800 card that I can try if that doesn't work.
    nForce 680i SLI
    GeForce 9800 GTX
stoneys-nutz
Gamerholic
Try the 8800 and see if that helps.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Thunck
I removed the 9800 and used a can of air on the contacts and the port before reseating it in. It didn't work. I still get that error when trying to update drivers. I guess I'll try the 8800 next.
    nForce 680i SLI
    GeForce 9800 GTX
fadedrs
Power User
does the card use a seperate power supply? or just the power from the slot?
if it uses a seperate power supply maybe switch it with another plug.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
Thunck
I swapped in the 8800 and got the same problem. Windows has found drivers for your hardware but encountered problems while trying to install. It then lists the correct card (did so for the 9800 as well) and says beneath it "Cannot find files specified". My wife has an 8800 GT so I went into her C:\Windows\inf folder and just copied her "nv_disp_XXXXXXX" folder over to mine and reattempted to update the drivers. It worked, but I can't update to the most current drivers, I'm stuck at the 178.13 versions. At this point I'm pretty sure it isn't the card, the PSU, or any of the hardware. I think there is something in the registry that won't allow me to install video drivers.
    nForce 680i SLI
    GeForce 9800 GTX
stoneys-nutz
Gamerholic
Here is a method that has worked for a lot of people, you will need two bit's of software, both are free, link's below.
1.Ccleaner.
2 Driver Cleaner.
Follow the instruction's and i think it will work.
I cant take the credit for this, it's from the Nvidia forum by a guy called Luttiano.
CCleaner - Download
Guru3D - Driver Sweeper (Setup) download from Guru3D.com
Normal Mode :
Turned off automatic driver updates (set to "never" was confirmed) [after done, reset to "ask before installing"]
Uninstalled Nvidia motherboard drivers
Uninstalled Nvidia display drivers
Ran DC.net cleaner [Driver Cleaner.NET]
--Cleaned nvidia
--Cleaned nvidia control panel
Rebooted
Safe Mode :
Ran DC.net cleaner
--Cleaned Nvidia
--Cleaned Nvidia Control Panel
Rebooted
Safe Mode :
Ran DC.net cleaner
--Cleaned Nvidia
--Do not reboot at this time.
[for the following reg changes, use search to find all occurences]
Opened Regedit and removed the nvidia CPL registry keys
Deleted the NVCP*.* files from windows\system32
Deleted any NVC file that housed a description of Nvidia Control Panel from windows\system32 [pass mouse over file and read "description"]
Used CleanMyPc Registry cleaner [or CCleaner] and fixed all registry issues
Rebooted
Safe Mode :
Installed Nvidia Motherboard Drivers [latest]
Installed Nvidia Display Drivers [latest]
[installed nVidia System Tools]
Rebooted
Normal Mode :
Display works 100%
Control Panel works 100%
Multiple Monitor Support works 100%
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
fadedrs
Power User
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
stoneys-nutz
Gamerholic
:roflmao::roflmao:LOL, sorry dude.:roflmao::roflmao:
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Thunck
I got it working solid and was even able to update to the newest drivers without problem. There is a new issue that I've narrowed down to World of Warcraft now so I'll post that under the Games forum.
Thanks for all the help!
    nForce 680i SLI
    GeForce 9800 GTX
stoneys-nutz
Gamerholic
Glad you got it working ok. Good work.:party:
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
