SYSTEM RESTORE Error
Could be a virus/malware. To start, go to Malwarebytes : Free anti-malware and download Malwarebytes. Install it, let it update, and then run a full scan. After the scan is done, remove everything it tells you to and restart your computer. Then tell me if you're still having problems.
    Dell Inspiron 1545
    Intel Core 2 Duo T6400 @ 2.00 GHz
    DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
    Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
    1366x768
    Internal 320 GB Portable 320 GB used for separate storage of media, plugged into USB port as needed.
    Single built in fan
    Touchpad, + Logitech wireless mouse (USB)
    Built in
    ~150 kilobytes/sec DL
    Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
Do you have Norton installed? If so I read that it should be disabled.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Yes Norton was the culprit with me, open norton, Click settings, untick the box's,
Norton tamper protection,
smart firewall,
Then try again, dont forget to tick the boxes when finished back to protection,
Better yet, get rid of Norton.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
    Dell
    Q6600
    HP w2207h
so i recently tried to restore my computer and when i clicked on it says "restore was unsuccessful and error is unspecified"
This is a second Thread by this user, and Norton has never been mentioned in this or the other thread, however, this user has a Bootsect.bak issue being addressed in the other thread here. : http://www.vistax64.com/general-discussion/293579-start-menu-completely-blank.html See the # 6 post by Monmil.. This gets confusing to assist this user with more than one thread.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
when i tried startup repair it says that "windows hasn't detected any problems" then when i tried system restore it said that it was already running..
So, does this mean all icons are back plus programs showing ? Are we down to just one issue as start up repair says you are good ?
Go to the task bar, right click , brink up applications tab in the Task Manager, highlight and then select end task for system restore. Then restart computer, and re-try your system restore program , if deemed needed to be run.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
To check if your attempt at start up repair fixed your issues , make a new restore pt, and then attempt to restore to that brand new pt. Post back results please.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
Not a good idea. Norton is by far the best AV program around.
Just a quick side question: why do you say that? I've been looking around at different AV's, and recently decided to go with MSE, as several people around here swear by it. (along with ZoneAlarm's great firewall) What makes you say Norton is "by far" the best?
    Dell Inspiron 1545
    1366x768
    Single built in fan
    Built in
For one, Norton comes out on top in most independent tests. Then I run it myself on 3 systems and NEVER had the slightest problems. I also run MSE on 3 other systems where I already caught nasties twice. Had to set those systems back to an earlier image.
That being said, there are certainly other fine AV programs around. G-Data comes to mind and would be my second choice. But MSE is only for the "light" user - in my opinion.
    Dell
    Q6600
    HP w2207h
But, MSE has never caused serious problems, like BSODs. A fact not true for other Anti Virus
Hmm. Didn't know that. Personally, I run MSE because A) people like Rich here recommend it, B) it's free, and C) I was sick of the resource-hogging McAfee caused me. Guess "light" was exactly what I was going for. I'm confident enough in my browsing techniques that I don't worry much about viruses, and MSE was the perfect lightweight tool I needed. Between that, Malwarebytes, and ZoneAlarm's highly-ranked free firewall, MSE was the way for me to go.
Thanks for the insight though :) I'll keep it mind for other people who aren't as browsing-savvy as I am, and are willing to shell out some cash.
    Dell Inspiron 1545
    1366x768
    Single built in fan
    Built in
