System Restore Related Errors
Adstringo
Okay, So my laptop was powered down incorrectly by one of my family members. I power back up and realize there is a problem with my system restore utility.
Whenever I start up System Restore this error occurs:
Incorrect Parameter
And when I attempt to change any settings in the System Properties Box I get these errors:
Mapping Error 1
Mapping Error 2
Any help with these errors or advice would be of much help.
Thank you.
Brink
Staff member
mvp
Hello Adstringo, and welcome to Vista Forums.
As a test, create a new administrator account to see if it works properly in it. If it does, then you can copy the contents of your old account's C:\Users\(User-Name) folders into the corresponding new account's C:\Users\(User-Name) folders.
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Brink
Staff member
mvp
You're welcome. Please let us know how it went for you. :)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Brink
Staff member
mvp
You might see if you are still able to do a System Restore at boot instead, and use a restore point dated before you got these errors to see if it can fix it.
If not, then I believe it may take a clean reinstall of Vista. :(
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Adstringo
Haha, the clean reinstall of Vista is just what I feared, but I guess that's probably my only way at this moment to solve this problem. I doubt my on boot system restore has restore points dating before this problem, but I'll try that also. Thanks for the advice!
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
