Task Scheduler Returned Error 0x2
lqd1967
I need to run a batch script to download files via ftp.
The script works fine on XP pro, deleting specified files from a local directory and replacing them with downloaded files from an ftp server.
When I run the script through Task Scheduler in vista, it only removes the specified files without downloading the replacements.
Just to add that I tested the bacth file manually and it worked fine.
I need help before I lose my head!
johngalt
Antidisestablishmentarianist
Hmmm - you can manually run the file and it runs OK? Did you allow the batch file privileges in the set up of the task scheduler item?
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
lqd1967
"Did you allow the batch file privileges in the set up of the task scheduler item?"
Thanks for your response. I'm not sure I understand this or how to it.
johngalt
I am assuming you manually created your task scheduler item for the batch file, so on the first tab (General) did you check Run with highest privileges
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
johngalt
Hmmm - OK, then it might be because batch files cannot be 'normally' elevated. have you tried saving it as a .cmd extension instead of a .bat extension to see if it works that way?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
lqd1967
I changed the extension to .cmd but got the same result. The old files were removed as expected but the script won't download from ftp. It returned error code 0x2
johngalt
When it returns that error code, what exactly does it say, just Error 0x2?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
johngalt
That is weird. Does the script have an exit command at the end of all the commands? Is the batch file located in the directory you want to copy to?
I am at a loss - I cannot understand why it would not work by TS and will in live....
Care to post the batch in a code box here so we can see what exactly you're doing, or does it have sensitive material?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
lqd1967
The files are all in the same directory as the destination. Here's the batch script:
del /Q C:\news\newsbreak.mp3
del /Q C:\news\toh.mp3
ftp -s:download.txt ftp.usaradio.com
AND HERE download.txt:
login
password
lcd C:\news
get newsbreak.mp3
get toh.mp3
close
quit
quit
exit
johngalt
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
lqd1967
I appreciate your time and help. But remember this is script that works perfectly well when I run it manually so i'm not supsecting anything wrong with the script.
Beside, I have been running the same script through scheduler in WIN XP PRO for a year.
Once again, thanks for your help. I am hopeful that someone will help me figure out what's different in Vista that's making this impossible via scheduler.
johngalt
I understood that perfectly when I read your post - but something has to be happening when the task scheduler calls starts trying to run the the script somewhere that is causing the issue.
If nothing else, perhaps *uncheck* the run with highest privileges. If that doesn't work, I'd move a bit lower in the forums and post it to a newsgroup - hopefully an MVP can help you there.
If you do find an answer, please let us know - I am very curious about this one myself.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
johngalt
That is a weird one. I am going to try to find an FTP site I can download from freely, and then see if I can use your batch successfully or not....
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
sidney1st
I think that you should write the path to the txt file.
ftp -s:x:\myfolder\download.txt ftp.usaradio.com
EDIT:
Just tried it and it works in task scheduler
1/ test.cmd
ftp -s:c:\users\myname\desktop\test1.cmd ftp.myftp
2/ test1.cmd
userid
password
lcd X:\test
get file.mp3
close
quit
quit
exit
lqd1967
Dear Sidney1st,
Let me quickly apologize for not responding to your post earlier. I've been on sick bed for 2 weeks.
I justed tested the script following your suggestion and it worked!
Once again, thanks and God bless you and Johngalt, really good, for your help.
