Solved Taskbar button height
alienglow
Hi Guys,
My Setup: Vista Home Basic 32Bit
Recently I downloaded a visual style Black by ~dimage on deviantART which I later removed as I didn't quite like it. The one thing I liked about the visual style is it had smaller taskbar button height. I have reverted back to the vista default visual style but wanted to know if its possible to reduce the button height using some advanced appearane setting or registry hack. I googled a lot and found this Change taskbar program button size which allows to change the button width not height. Can anyone please help. I have a screenshot of the buttons here, the left one is vista default visual style and the right with the custom visual style.
Thanks in advance,
Alienglow
acdcfan
Vista Pro
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP
    500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner,
    15 in 1 card reader
    Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
Brink
Staff member
mvp
Hello Alienglow, and welcome to Vista Forums.
You can use the Advanced Appearance settings to change the item Caption Buttons size (step 6A) to a larger number (step 6B) to accomplish this.
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
alienglow
Sorry but this didn't work either. The height of the taskbar button remained the same, although the size of the icon on it did change. Any other suggestions or is this something which has to be done using a custom msstyle and cannot be tweaked by itself.
Thanks,
Alienglow
Brink
Staff member
mvp
Sorry AlienGlow. To make the taskbar taller or wider to help make them bigger also, you will just need to unlock the taskbar and drag it to the size you like and lock it again.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Airbot
Hi Guys,
Thanks in advance,
Alienglow
Hi alienglow,
When you say "taskbar buttons" do you mean the icons on the taskbar? Your link to your screenshot doesn't work. Have you thought of auto hiding the taskbar itself?
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    [email protected]
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
johngalt
Antidisestablishmentarianist
The taskbar itself. If anyone looks at the link the OP posted in the first post, it is evident that the taskbar is thinner there than in a standard Vista install.
@alienglow - As for fixing that in 'standard' Vista, I do not think it is possible without some serious resource editing, or else hacking the native Vista style. What you could do is to reinstall that theme, and then revert all your icons and such back to the normal Vista style, thereby getting a hybrid of your thinner taskbar and the rest of your Vista style.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
If you want a thicker taskbar, do what BRINK said (always do what he says) and all the icons in it will fill up (get taller) with the widened taskbar. Make sure, as BRINK said, the taskbar is unlocked before it can react to your arrow placed on top edge of taskbar. You know taskbar is ready to be dragged up when arrow morphs to a two headed arrow.
And always lock taskbar when done ...or you can accidentally misplace/displace it all over the screen.
    HP Pavilion dv7-1170us
    Intel Core 2 Duo T5800 @ 2.00GHz
    Compal
    NVIDIA GeForce 9600M GT
    1440 x 900
    289.09 GB
    Synaptics PS/2 Port TouchPad
    IBM enhanced (101-or 102) keyboard
    cable Wireless
johngalt
Hi Guys,
Thanks in advance,
Alienglow
Not thicker, OK?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Oh, ok, then just do the opposite....drag it down.
    Compal
    1440 x 900
    289.09 GB
    cable Wireless
johngalt
It won't drag down smaller than the default size, which is larger than the size used by that theme.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
alienglow
Thanks everyone for your responses. Johngalt has understood my problem correctly. I basically need a thinner (height) taskbar. I don't like icon grouping and I like to have atleast three rows of taskbar icons. Problem is I have a widescreen laptop and vertical area as it is is less, and with a 3 row taskbar, I hardly get left with any area for my appliactions. With the stlyesheet I mentioned I could have 3 rows in roughly the same height as the default Vista uses for 2 rows. Guess there isn't a simple fix. Will keep you guys poseted incase I come across any.
Thanks again. And yes, here is the screenshot again
Airbot
Thanks for the update alienglow. Glad you found a solution.
    Airbot 2.0
    ASUS Xonar D2X
    [email protected]
    Corsair HX1000W
    Windows 7
    Windows Vista=5.9
