Taskbar clock
Hi, am using Vista Home Premium on a 9 mo. old eMachine...and want to know:
How can I get the clock on my taskbar to shown the seconds along with the hour and minute?
Many thanks.
    Dell T5062 X86-based PC
    AMD Athlon(tm) 64 Processor 3800+, 2400 Mhz, 1Core(s), l Log
    1 GB
Dzomlija
Resistance is Futile
south_africa
Many thanks.
The clock on the taskbar by design cannot display the seconds.
As an alternative, use the clock of the sidebar, and adjust it's settings to "Show the second hand". (To get to the settings, hover the mouse pointer over the clock gadget, then click on the wrench icon).
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
Zoloft
NothingCleverToSay
Power User
usa us_nevada
or you can install clock software. I am using 1st Clock. The most popular 32bit choices are Chameleon Clock and Atomic Alarm Clock. These are not free though.
Dwarf
The Contemplator
england uk_yorkshire
Hi Learner,
Sorry, that is not possible with the built-in clock for the system tray. As Peter says, you can have the sidebar clock set to show the seconds and/or as Zoloft says, you can install an alternative clock. This does seem to be a long-standing situation with Microsoft and Windows, going back to Win95. In all cases, the time format is set through regional settings, and you can set it to show the seconds there. It appears with the seconds (if you select them) in the preview box but NOT in the system tray. Whether this is a bug that has got overlooked or whether it is intentional I cannot say.
Dwarf
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
pers
australia au_south_australia
The lack of functionality in the taskbar clock is an one of those niggling little things I've always been disappointed with in Windows. The Vista feature to add additional clocks is slightly better.
The solution I am using is called TClock Light. I am running Vista Ultimate 32bit. It allows me to adjust the way the clock displays in many ways. It has some additional features but I don't use them, I only wanted to change the way the clock displays so the font is bigger.
One caveat is that using this will make the additional clocks feature in Vista unavailable.
I got TClock Light from TClock Light
Regards,
pers
