Solved taskbar look
How do I or how can I change the look of my task bar with having to buy a program. I kinda like the look of apples task bar, icons across the bottom. Any ideas. Thanks
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
Have a look Here
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    Samsung 32" TV
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB
    68 MB Down 18.5 MB Up
You can sort of put icons across the bottom by moving the Quick Launch toolbar around, maybe changing it to 'Large Icons'.
    Intel Core 2 Duo @ 2GHz
    4GB DDR2 @ 667Mhz
    nVidia GeForce Go 7600
    1x 160GB 7200rpm 2.5" SATA
ObjectDock is another solution...I run it along with RocketDock with no problems.
Stardock ObjectDock
I use the free version, but ObjectDock Plus ($$$) gives you the ability to add more than one dock and various other features. I have one dock on the left side and one along the top and it works great.
    Homebrew
    Q6600 (G0) SLACR
    Gigabyte EP35 DS3R
    2 gigs G.Skill DDR2
    XFX 8600GT
    Samsung T190 1440X900
    1440X900
    2X Seagate 120 (OS's) IDE
    1X WD 750 SATA
    Corsair HX520
    Coolmax el cheapo
Thanks guys that's what I was looking for. I think I go with stardock/objectdock plus. It's more to my liking. Thanks again.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
No problem...enjoy :)
    Homebrew
    Q6600 (G0) SLACR
    Gigabyte EP35 DS3R
    2 gigs G.Skill DDR2
    XFX 8600GT
    1440X900
    1X WD 750 SATA
    Corsair HX520
    Coolmax el cheapo
Enjoy Stan :)
    Homebrew
    Q6600 (G0) SLACR
    Gigabyte EP35 DS3R
    2 gigs G.Skill DDR2
    XFX 8600GT
    1440X900
    1X WD 750 SATA
    Corsair HX520
    Coolmax el cheapo
