Solved Taskbar not locked, but won't move
StoneMoJo
5
My taskbar is stuck at the bottom. I've tried unlocking and locking, it still won't work. While unlocked, the layout is very strange, most items are hidden and available only by scrolling. I've tried rebooting. I've also tried ending the process explorer and restarting. Any ideas? FYI, I normally move several times a day from side to bottom and back depending on the programs that I am using at the time. Thanks!
StoneMoJo
5
Normally the quick launch icons or on the far right, two rows. When I unlock the taskbar, it goes to 1 row. Also, when locked, the open windows are indicated across the center of the task bar in long narrow rectangles (as long as I don't open too many, obviously). When I unlock, they all move to the right, only two showing, and I have to use an arrow to scroll up and down. The rest of the task bar remains blank. Sorry I'm not better at the description!
Bare Foot Kid
R.I.P. August 13th 2014
2,616
Location
The Lowcountry
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Bare Foot Kid
2,616
Location
The Lowcountry
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
ripbox
Nerd
Vista Pro
591
#8
it seems to me when you have unlocked your task bar you have stretched it
if so unlock it go to the top or bottom edge of your task bar dependant on if its at the tom or bottom of your screen to the point that you see an arrow pointing up and down left click on it and drag it back to normal size you can then happily re lock the task bar also the vertical bar to the right of your task bar in the 1st pic do the same and drag it to the left
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    150GB Raptor HDD
    500GB Caviar HDD
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
johngalt
Antidisestablishmentarian
3,922
Location
3rd Rock
#9
What happens is that when unlocked the Quick launch bar is taking the majority of the taskbar space - so when you try to drag it you cannot.
See the edited pic below:
Now, grab in the highlighted area in the blue circle and you'll be able to move it.
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Classified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    300+ Mbps downstream / 30+ Mbps upstream
    Windows 10 Insider Preview (current)
    Dell Inspiron 3521
    Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
    Dell
    Intel(R) HD Graphics
    Intel(R) Display Audio | Realtek Audio
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Logitech MX Master | Synaptics TouchPad
    Dell
    300+ Mbps downstream | 30+ Mbps upstream
ripbox
Nerd
Vista Pro
591
#10
stonemojo seems to have fixed this issue now
here is his thanx he posted in my rep tap
It hadn't stretched and didn't change shapes, but after I tried that, it worked!!! Thank you!!!!
thank you stonemojo im glad to help
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    150GB Raptor HDD
    500GB Caviar HDD
    Antec 900
Bare Foot Kid
2,616
Location
The Lowcountry
#12
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
