TCP/IP access denied on new wireless dongle
Burn9900
3
Ok so i bought a new netgear usb wireless dongle. Installation of the drivers went okay but i only get limited connectivity. I check the adapters settings and for some weird reason IPv4 does not install. When i try to install it manually i get "access denied" Im on an administrator account so it shouldnt be a permission issue. Everything else will install manually. I assumed it didnt support Vista 64 so i took it back and got a new one that does support it. Getting the same exact access is denied message. I installed the adapter to another computer and it worked great, so i have no flippin clue why IPv4 will not install on this adapter. any ideas?
AstaLaVista
Lost in Cyberspace
Vista Pro
1,234
Location
Miami, Florida. USA
Were the drivers from Vista or the manufacturer of the dongle?
I have found that the best way of doing this is to let Vista install its drivers, then I go to the file where I have my new drivers, right click on the file and use the "Run as Administrator"
Was this other computer also using Vista Premium or XP?
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    WD Velociraptor 160GB
    Samsung Sata 750GB
    Maxtor External 160GB
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
Burn9900
3
i used the manufacturers drivers. Im running vista 64 home premium. Its a Dlink DWA-160. Ill try letting windows run the driver install and run as administrator. whats confusing me is why vista will let me install :client for windows, IPv6, and all the other services and protocols but when i try to install IPv4 it cuts me off with this access denied stuff.
The other computer was running Vista 32 home premium
