Temporary Files - Temp Folder
ByLine
How to Clear Vista Temporary Files in the Temp Folder
Synopsis
This will show you how to clear the Vista temporary files through Disk Cleanup or manually in the Temp folder.
The Temp folder is where Vista and programs sometimes store temporary files. Sometimes these files are not deleted after Vista or the program is finished with them. This can cause the temp folder to fill up with junk temp files which may cause Vista to take longer to access the Temp folder and create a slight delay.
The Vista Temp folder is located at:
C:\Users\(User-Name)\AppData\Local\Temp
While it is safe to delete these files, it is best not to do this while installing or uninstalling anything.
CCleaner is a free program that is great at keeping the temporary files cleaned up and more.
EXAMPLE: Vista User Account Temp Folder
METHOD ONE
Through Disk Cleanup
Disk Cleanup will only delete Temporary files that have not been modified in 7 days. To clear everything, see METHOD TWO below, or How to Set Disk Cleanup to Delete Vista Temporary Files Less than a Week Old .
1. Open Disk Cleanup.​
2. Check Temporary files. (See screenshot below)​
3. Click on OK.​
4. Click on Delete Files to confirm the action.​
METHOD TWO
To Manually Clear the Temp Folder
The Temp folder is located at the hidden system folder:
C:\Users\(Your Username)\AppData\Local\Temp
1. Open the Start Menu.​
2. In the white line (Start Search) area, type %temp% and press Enter.​
NOTE: This opens the Temp folder.
3. Delete anything you want in this folder. (See screenshots below step 4)​
If you delete the Low folder, it can prevent you from printing from Internet Explorer. To fix this, close all Internet Explorer windows and reopen Internet Explorer to recreate the Low folder. You can also manually fix this by recreating the Low folder in the Temp folder below, open a elevated command prompt, then Copy and Paste the command below in the command prompt and press enter.
Code:
icacls %UserProfile%\AppData\Local\Temp\Low /setintegritylevel (OI)(CI)low
If you receive a File In Use error message while the files are being deleted, then this just means that one of the temp files is in use by a program right now. Click Skip to continue deleting the other files, then close all open programs, and repeat the steps above. If you still receive the message, then restart the computer or logoff and logon, and repeat the process again. (See screenshot below)
4. Close the Temp folder when done.​
Related Tutorials
Brink
Staff member
mvp
Hello Nerone, and welcome to Vista Forums. :party:
You're welcome. Glad you like it.
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
.Joe
1337 spammer
Excellent tutorial Shawn. Keep up the great work :)
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main
    500 GB USB External
    160 GB USB External
    2TB USB External
    DSL 3MB
Brink
Staff member
mvp
Thank you .Joe.
    Lumia 1520 phone
Brink
Staff member
mvp
You're welcome Rajah. I'm happy to hear so.
    Lumia 1520 phone
Brink
Staff member
mvp
Hi VistaKing,
Logging off and on, or restarting the computer, will have Vista automatically replace the folder. I will add a note to the tutorial to warn others of this.
Thank you,
UPDATE:
Just close and reopen IE7 to recreate the Low folder.
    Lumia 1520 phone
VistaKing
Banned
Hi VistaKing,
Thank you,
Shawn,
I tried restarting the computer and it didn't bring back the " low " folder. I had to recreate it and then open up CMD with Administrator rights and typing this in " icacls C:\Users\UserName\AppData\Local\Temp\Low /setintegritylevel (OI)(CI)low " .
Brink
Staff member
mvp
Thank you for the feedback VistaKing. I have added this to the tutorial to help others.
    Lumia 1520 phone
Kotuku
Power User
Great Tutorials and Tips - I love 'em all!
Can you expand on the LOW folder in TEMP? I didn't have one and no doubt deleted it at some stage, as I regularly manually empty this folder. But have had an intermittent fault while printing within MYOB. Sometimes does, sometimes doesn't (only since changing to 64 Bit Vista). I have re-installed the LOW folder as per your tutorial and just tried printing from within MYOB and it worked. Usually I have to disable UAC, reboot and then do the printing, then re-enable UAC and then it will print until next shut down/restart of the machine. I wonder (and it is early days) if this was effecting print, as your comment that it may cause IE problems, prompted me to look.
Many thanks
Kotuku
    Intel Core2 Extreme Quad Core
    XFX MB-N790-IUL9 NFORCE 790 U
    4 Gb (2x2) Gskill DD3 1600
    XFX 9800GX2 Black Ed. 1Gb DD3
    2x WD Raptor 150 Gb SATA 10000rpm in Raid0 plus 500 Gb Seagate 7200rpm SATA2
Brink
Staff member
mvp
Hi Kotuku,
I bet it was effecting the print problem you were having. The Low folder is used to store these print jobs temporarly until done. The command sets the correct permission level for the Low folder after recreating it.
I'm happy to hear that it is working for you now,
    Lumia 1520 phone
micjustmic
Hi VistaKing,
Thank you,
Actually, I've noticed that simply restarting Internet Explorer (in Vista) will recreate the Low folder, no log-off or re-start needed.
Mic
    Intel Core2 Quad [email protected]
    Gigabyte GA-EP35-DS3L
    4 Gig Kingston SDRAM DDR2 1066 (PC2 8500)
    SAPPHIRE Radeon HD 2600XT
    WD 1 TB
SCSIraidGURU
If you move your temp folder to a new drive, you need to give your user full control to the low folder in order to print in IE.
    16GB DDR667
    SAS RAID
Brink
Staff member
mvp
Thanks Mic for the feedback on that. The tutorial has been updated.
    Lumia 1520 phone
VistaKing
Banned
Hi VistaKing,
Thank you,
Mic
Mic,
I've tried restarting Internet Explorer and the LOW folder didn't recreate itself.
micjustmic
Hi VistaKing,
Thank you,
Mic
Mic,
Interesting . . . I've tried this on several computers and in several VMs and it worked almost every time.
The only time I noticed it didn't work was if iexplore.exe wasn't terminated completely.
Check in Task Manager to make sure the exe terminated.
Sometimes closing all IE windows will still leave the derned thing running in the background until Windows figures out that it should have been terminated.
Mic
    WD 1 TB
bennys
Hello!
I deleted all junk files in local\temp except two. first error says this file no longer locate in local\temp. So it won't allow me to delete it. I know for the fact that I saved it in my E: drive CD(which is now destroyed).
The second error:
BROKEN LINK REMOVED
It does not give me the SKIP option.
Is there any way to get rid of it?
Thanks.
