The difference between LAN and the internet
mattinahat
m@thue
Power User
From http://www.vistax64.com/graphic-cards/212327-better-cpu-better-graphics-needed-2.html#post978038 (sorry smarteyeball)
The internet is a big world where websites and such are accessible (some will dispute the differnce between internet and the 'web' but lets not get into that)
A LAN is a Local Area Network. HUGE difference.
A LAN is much, much faster. A LAN is only accesible over a limited range as it cannot be run over the internet (Hamachi sort of does this but different).
I have tennis right now so I have to go but if anyone wants to add more please do :D
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Coolermaster Silent Pro 700M
    Antec 900
    Tuniq Tower 120 LFB
    Logitech EX110
    Logitech MX400
    Graphics Driver - 190.38
so. just say i have 864kibs download speed. and i use wired connection. i get about 90kb download. if i use lan would it be like 150kb?
    amd 64x2 4200+ 2.2ghz per core
    ECS NETTLE
    3 gb
    nvdia 6150se nforce 430(old rig, upgrading)
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    upgrading, Coolmax CA-450 450watts
    hp casing
    defult..
    hp
    hp
    768kbps down and 128 up...very slow..
    not great compared to other people..
Thanks Matt. Makes more sense in context :)
The network speed would be faster in this case. But if your talking about from the net, then you are still limited to to 90KB/s.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
Forget about your internet speed.
A LAN has nothing to do with internet.
A LAN is a centralised connection whereas the internet is distributed.
A LAN is either 10, 100 or 1000mbps.
A LAN can be wired or wireless (WLAN if wireless).
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Antec 900
    Tuniq Tower 120 LFB
    Logitech EX110
    Logitech MX400
lol. what the point of lan? it doesnt increase ur speed.
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
ya. i know. but im all for SPeeD
vroom..
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
If you are single non-networked PC connected to the net, then LAN speed will do nothing for your vroom. It's your ISP that is slow.
If for example you had a small network with 5 PCs and needed to download and copy a 1GB file to each of those PCs, you would download at 90KB/s to one PC. Then you would transfer that 1GB file at vroom speeds (8-13MBP/s real speed) to the other 4 PC's.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
If you didnt have a LAN connection then you wouldnt be able to route the internet you have to other computers, I couldnt live without a LAN, heres a simple test, if you have 2 computers, connect them to your router, and swap files between them, thats your LAN speed, downloading files from the internet is your connection speed rated by your ISP(internet service provider).
You can understand what LAN means by asking yourself what it stands for, LOCAL area connection, local means at home, transfers happen at home. You dont need internet at home to use a LAN, it can be functional and practical at the same time, I used to watch DVD's over LAN, sharing the root drive and double clicking the shared folder and playing it over LAN.
Heres how it works though,
Internet ------Router-------Home computers
.............................^^^^thats your LAN
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Alright,
A LAN is a LOCAL AREA NETWORK.
NOT the internet. You can have a LAN (or WLAN) set up between your computers, but that doesn't need to be connected to the internet (i.e. Government facilities). Home networks (anything with more than one computer) as well as small (and large) business networks are all LANs. Then, there is usually a hub or router, and that is hooked to a modem, to the internet.
The transfer speed along the LAN is 10,100,1000 as stated above, but the transfer speed from the internet (upload/download) is limited by both your ISP, your router, and your cabling.
Kiddieboy, you don't NEED a LAN, but if you have more than one PC, then yes, you DO. Unless you plan to pay for a modem and ISP for each computer and NOT go Wireless.........
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Tarantula
    Razer Lachesis
    not fast enough
Alright,
~Lordbob
ooo bob, i just noticed you changed your display pic, nice :p
    16Mb Sky bb
Lol yup. I wanted to change by Profile pic too, but it looks like John disabled that. :(
I had an amazing drawing I used for my facebook profile I wanted to use....
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Tarantula
    Razer Lachesis
    not fast enough
    16Mb Sky bb
I can click it, but it says I don't have permission, or the admin has blocked it out...
I had found that link before, but it doesn't work. :(
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Tarantula
    Razer Lachesis
    not fast enough
it works for me m8. get onto zer010 or brink, john might have done it if you annoyed him :zip:
    16Mb Sky bb
LOL I don't recall piddling off the admins!
It's probably because I asked Brink like a 1000000000000000000000000000000000000000000000000000000000000000000000000 questions.......
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Tarantula
    Razer Lachesis
    not fast enough
