"The security center has not recorded an anti-spyware product."
prukeyhi
Workaholic
Power User
A new problem since last 2 weeks:
I have Microsoft windows defender installed.
In Vista's Reliability and Performance Monitor, I continually get this message:"The security center has not recorded an anti-spyware product."
on control panel->security, defender is recognized!
the defender update/work fine...
how do i get rid of the above "error" in
In Vista's Reliability and Performance Monitor?
Thanks in advance
ps-i do not use MSE
    LENOVO G-530
    # Intel Pentium Dual-Core T3400 (2.16GHz, 1MB L2 cache, 667MHz FSB)
    # 15.4-inch glossy 16:10 display (1280x800)
    # Intel Graphics Media Accelerator 4500MHD
    # 3GB DDR2 667MHz RAM
    # 250GB 5400RPM HDD
    # SuperMulti DVD+/-RW Optical Drive
    # Broadcom WiFi (802.11b/g), 10/100 Ethernet, Modem
    # 6-Cell 11.1V 53WHr Battery
    http://www.notebookreview.com/default.asp?newsID=5022&review=lenovo+g530
mitchell
Ngai Tahu/Tau Iwi
    Hewlett Packard, compaq presario CQ60-305AU
    AMD Athlon QI-46 2.1 Ghz
    Wistron 303C
    2048 Mb DDR2 SD Ram
    NVidea GE Go Force 8200M G / 256Mb dedicated grapics memory
    MCP78S NVidea High definition
    15.6" High Definition Brightview Widescreen
    1336x768
    Toshiba MK2555GSX ATA
    Synaptics PS2/Touchpad
richc46
how do i get rid of the above "error" in In Vista's Reliability and Performance Monitor?
Thanks in advance.
ps-i do not use MSE
You need either MSE or another a/v software. What A/V software are you using? You only mention that you do not use MSE.
prukeyhi
Workaholic
Power User
mitchell- thanks, but there's no solution in your post...
rich64-i do not use AV at all, and i'll not install MSE .
(i do not need MSE since There was no error problem before, only now)
[is there a way to re-register defender in Vista's Reliability and Performance Monitor?]
    LENOVO G-530
    # 250GB 5400RPM HDD
richc46
Ok so if I am correct, you are not saying that Defender is giving incorrect information, you just want to turn off the warning?
richc46
I have two answers for you, my answer and then the one that you want?
My answer is get an anti virus. There are many free ones out there that are very good. It does not have to be MSE. I hope you do not think that I am out of line, but I treat every member that I help like a friend, trying, only to do the best for them.
The second answer is from one of our fine tutorials:
http://www.vistax64.com/tutorials/69601-windows-defender-notification.html?filter[11]=Security System Tools
I hope that you choose my first option.
If not, I hope that the tutorial works for you. And that you have happy and safe surfing.
Take care
prukeyhi
Workaholic
Power User
-No,it's not the defender it self giving incorrect information,
it's the Vista's Reliability and Performance Monitor who gives incorrect information: "The security center has not recorded an anti-spyware product."
(the defender works fine)
-thanks rich64, but i don't want to install AV.
-WMI repository is consistent (fine)
    LENOVO G-530
    # 250GB 5400RPM HDD
richc46
prukeyhi
Workaholic
Power User
    LENOVO G-530
    # 250GB 5400RPM HDD
richc46
I understand that you want the warning stopped. From my stand point, however, the system is working correctly, now. It was not, when it did not warn you. I can not think of anything else to change the way the system is working, now. It is programmed to warn if you have no Anti Virus installed.
If someone else with more expertise, in this are comes by, they may be able to help.
My sincere wish is that you get the system working the way you want. Sorry that I could not be of more help.
prukeyhi
Workaholic
Power User
-yes
-yes, the defender works fine.
-no problemo. :) you did try and i thank you again for this!
-i do hope an microsoft/defender update will fix the issue in the future....
    LENOVO G-530
    # 250GB 5400RPM HDD
mitchell
Ngai Tahu/Tau Iwi
I am sorry prukeyhi, the link i provided was not inteded to supply a solution. It was intended to show you that (just not on my say so) it is a well known glitch with the Performance & Reliability Monitor
So long as it is displaying as active & up to date (Green) in the Security Center I would ignore the Reliability & Performance Monitor as stated by others in the link i posted.
I do wish you would reconsider the sound advice RichC has given you about useing an Anti Virus :confused:
Edit; I just run a check on my system & as you can see it says i have no anti virus
I can assure you i have & if you look at the bottom of the pic Security has a green light.
    Wistron 303C
    2048 Mb DDR2 SD Ram
    1336x768
derekimo
Moderator
Mine is the same way too mitchell and I have A/V.
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    250GB Samsung 850 EVO SSD
    1TB WD Blue
    1TB Hitachi
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
    Laptop specs: HP g7-1365dx /
    CPU: AMD A6-3420M APU with Radeon(tm) HD Graphics /
    RAM: Crucial 8Gb (2x4Gb) /
    SSD: Crucial M4-CT128M4SSD2 ATA Device/ FW 000F /
    GFX: AMD Radeon HD 6520G /
    OS: Windows 10 Pro x64
prukeyhi
Workaholic
Power User
Thanks mitchell- my problem is new, it was not before with anti-spyware product (not AV)recognition.
    LENOVO G-530
    # 250GB 5400RPM HDD
niemiro
Banned
Windows Defender does not count as a true Anti-Virus. It is not as good as a proper anti-virus (and does not pretend to be) and therefore Windows WILL NOT show it up as Anti-Virus software. Without disabling this message (see above posts by richc46), there is nothing you can do. It may be that these messages were disabled and are now not for some reason, but it will never show up as an Anti-Virus software, which is what you are asking for.
Hope this clarifies things a bit.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
prukeyhi
Workaholic
Power User
hi
i know Defender does not count as a true Anti-Virus.
you are mixing something i think,
1-my problem is fault anti-spyware notification warnning not AV .
2-disabling this message is impossible since it appears in Reliability & Performance Monitor only
    LENOVO G-530
    # 250GB 5400RPM HDD
derekimo
Moderator
hi
I know the message you're talking about, Over the last two years I've had 4 or 5 different A/V and Anti spyware products and I have continuously seen that message, I don't know why it shows up, but I know I'm protected.
I know that doesn't answer your question, just wanted to say I've seen the message also.
    Asrock P67 Extreme4
    auria eq2367
    1TB WD Blue
    1TB Hitachi
prukeyhi
Workaholic
Power User
thanks derekimo ,
i know that my pc is protected with DEFENDER,
but the fault anti-spyware notification warnning just drives me mad :mad:
    LENOVO G-530
    # 250GB 5400RPM HDD
derekimo
Moderator
    Asrock P67 Extreme4
    auria eq2367
    1TB WD Blue
    1TB Hitachi
