This problem was caused by Bitdefender Antivirus
ripbox
Nerd
Vista Pro
I installed Windows Vista Home Editition and avast antivirus home
edition. Windows gives me a problem report for a problem cause by
Bitdefender Antivirus, but I didn't install that (I think). It's not
in the list of software where you can remove software (control panel),
it's not in my start menu and there's no Bitdefender folder in my
program files. Why does Windows Vista seem to think that I have
Bitdefender Antivirus?
Veerle
i Just got this very same problem as i booted my pc... b4 window booted ny system blue screened... i have avast, is avast and Bitdefender Antivirus the same company?
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    150GB Raptor HDD
    500GB Caviar HDD
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
johngalt
Antidisestablishmentarian
Not that I know of....
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Calssified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    2 * Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA II
    Seagate Barracuda 7200.12 ST1500DL001 1.5 TB SATA II
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    180 Mbit down / 15 Mbit up
    3 VMs built off IP 14971:
    UUP disabled / single VHD | UUP disabled / dual VHDs with moved \User Tree | UUP enabled / single VHD
BitDefender Anitvirus software has nothing to do with Avast. There are some other antivirus software that are using the BitDefender scan engine, but that's not the case here.
The problem is probably caused by an old nick-name of Windows Defender.
