Solved To Clone or not to clone?
cfourkays
Banned
I have my Vista Ultimate on a Seagate 300G SATA.
Been using it since Jan, 07, and its getting kind of clogged.
Installed a new 500G I'll use as boot primary, its in and formatted.
If I clone the entire mess over, I'll just bring the pieces over to a larger drive.
I'd like to just change the boot order and install Vista like new than move and install programs and files.
Anyone see any problem with activation or my plan?
Thanks, Pete
    AMD Athlon 64X2 Black 5000+
    Asus M3A
    2 G
    Nvidia 8800GTX
Brink
Staff member
mvp
Hi Pete,
If you just want to copy what you have to the new hard drive, then a clone would be the easiest way of doing this.
Doing a clean install on the new drive will get rid of the junk that you do not want, but it is more work of course.
Either way, since it is a new hard drive that Vista is on, you may end up having to do a phone activation. This will show you how if you need to. It's easy.
http://www.vistax64.com/tutorials/84488-activate-vista-phone.html
It's your choice, but I do not see a problem with either way.
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
cfourkays
Banned
Thanks, Shawn.
I'll go the clean route.
I've called MS before with no problems but never on a Vista install.
    Asus M3A
    2 G
    Nvidia 8800GTX
Brink
Staff member
mvp
Your welcome Pete.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
