Too much memory used
Hey guys, I need your help. I'm currently experiencing a problem with my laptop running Windows Vista Ultimate and having 2 Gigs of RAM. My system is running very slowly and is using TONS of memory (up to 97%) even if there are no programs running. Normally, it uses less than 50% memory. I started experiencing this problem after firefox (version 3) did an automatic update to firefox 3.X.x, i forgot the version.
After the automatic update, my system started to run very slowly,became very unresponsive, and used a lot of RAM. I thought the problem was caused by the firefox version I was using so I installed the latest version of firefox, version 3.5.2. After the Firefox update, the problem still occurs and my laptop is still using a lot of memory and running very slowly.
My system has very few programs that run on start-up and has been pretty fast since I bought it several months ago. This is first time that I experienced problems with it.
I did a virus scan and also scanned for malware but both scans didn't find anything. I then tried hijack this and came up with this log file. I hope you guys can help me fix this. Thanks in advance.
ilikefree
Have a look in task manager to see what is the highest reading in the Memory(private working set) in the Processes tab
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Lorien
Account Suspended
Hi Smilence,
If you would like to see a clearer picture of what is using up your CPU, download and run Process Explorer Process Explorer which is quite a bit better than Task Manager and may help you fine tune your options (what and how much can be open at the same time) more easily and also help identify the processes more easily.
Also, there may be many things running in the background that may not be required but taking up valuable resources (maybe not big individually, but a lot collectively). I recommend you download Autoruns Autoruns for Windows and click on the Everything Tab and see what programs are running at startup and remove/uncheck any that you don't require - you can always easily add one back later if you find removing one proved to be inconvenient). Do this only for programs - do not do it for services (at least for now and not without guidance) - and if you don't know what something is, either find out what it is first or leave it alone until you do know (some changes especially if not to program can cause serious problems - so be SURE before you uncheck anything that you don't know for sure is a program that isn't needed or that you want and, again, uncheck nothing but programs at this point). Remember, many programs that run at startup are NOT required for the program itself to run if you want to use it but there to make it start faster or to automatically check for updates or other reasons that may not be necessary and can reduce the load on the CPU.
If you want, in Process Explorer go to File / Save As and save it as a .txt file and then attach the file to your next post and we'll see if we can identify what is running and what can be done to decrease the impact (if we recognize them ourselves). You can also do the same with Autoruns (make sure you choose a .txt file type) and that may also help us to help you.
I hope this helps.
Good luck!
    1920 x 1200 pixels
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
