Toshiba Satellite A 300 with Vista x64 will no longer boot up
southofzero
After a power outage Vista will no longer boot. I am unable to get a successful boot into Windows Vista operating system. It seems the boot file or the registry have misplaced pointers or corruption.
Powering on I was only able to reach the Bios settings. The initial error message was Status: 0xc00000e9 an unexpected I/O error.
More recently it is : 0xc000000f windows failed to load because the system registry file is missing or corrupt
This Toshiba laptop did not come with a Vista OS CD so I have purchased the Vista x64 Easy BCD Recovery CD from Neosmart. None of the tools have been able to fix the problem /s
The Automated Repair function log states : No O/S found
Repair required is the partition table
Failed Error Code : 0x 490
I have been reading threads here and running a variety of diagnostics to try and determine what the problem is without any success so far.
Bootrec.exe / rebuildBCD produces the error " the request could not be performed because of an I/O device error "
BCDedit.exe /enum " boot configuration data store could not be opened. Cannot find the specified file. "
SFC / Scannow produces the error " windows resource protection could not start the repair service "
Chkdsk fails to complete successfully indicated an unexpected error was experienced.
Would very much appreciate the exceptional expertise of the wizards here.
    Toshiba Sateliite A300
    Intel 2.0 GHZ
Yard Dog
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    Acer E181H ([email protected]) 128MB GeForce 6150SE nForce 430 (
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
