Touchpad and Keyboard?
ryen2324
i have a gateway laptop and for some reason, the touchpad and some of the keys on the keyboard wont work anymore. i have tried updating the drivers and nothing has worked. any ideas on anything else i can try to fix this?
    Toshiba Satellite A135-S4427
    Toshiba
    120 GB hhd 1GB ram
    Integrated Intel GMA 950
    15.4-inch TFT
lordbob75
Lord of Bobs
Vista Pro
How old is the laptop?
It could just be going south...
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
ryen2324
late 2007
    Toshiba
    120 GB hhd 1GB ram
    15.4-inch TFT
lordbob75
Lord of Bobs
Vista Pro
Hmmm.... Should be ok then.
Can you access device manager? Is the keyboard listed??
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
ryen2324
can access every thing. under the device manager the keyboard is listed no problems seem to be occurring. but for the touch pad there is a problem and i dont know how to fix it.
    Toshiba
    120 GB hhd 1GB ram
    15.4-inch TFT
lordbob75
Lord of Bobs
Vista Pro
OK..... If you turn off the touchpad, does the KB problem disappear?
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
ryen2324
do you mean disable the touch pad?
    Toshiba
    120 GB hhd 1GB ram
    15.4-inch TFT
lordbob75
Lord of Bobs
Vista Pro
Yes. I want to see if the problems are linked.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
ryen2324
already tried disabling it and nothing happens with the keyboard. it just stays the same
    Toshiba
    120 GB hhd 1GB ram
    15.4-inch TFT
lordbob75
Lord of Bobs
Vista Pro
Interesting...
If you plug in a secondary keyboard, does it work?
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
ryen2324
the secondary keyboard does work
    Toshiba
    120 GB hhd 1GB ram
    15.4-inch TFT
lordbob75
Lord of Bobs
Vista Pro
Ok, so it is a problem with the built in keyboard. Unfortunately, I think that it is broken, and has to be replaced....
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
ryen2324
damn. what do you think about the touchpad? could it just be disabled under the function keys? if so which ones should i try. i dont have use of some of them because of the keyboard.
    Toshiba
    120 GB hhd 1GB ram
    15.4-inch TFT
lordbob75
Lord of Bobs
Vista Pro
Go into device manager and check to make sure that the touchpad is enabled. If it is, go to control panel, mouse settings, and check to make sure it is on there.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Fastboy42
Banned
try disabling touchpad from bios then add an external mouse.
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Optical
    Logitech Cordless Desktop EX110
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
lordbob75
Lord of Bobs
Vista Pro
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Fastboy42
Banned
Quote:
Fastboy42
That wont fix the keyboard.
~Lordbob
The touchpad might be conflicting with the keyboard:eek:.
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
ryen2324
how do i disable it in BIOS
    Toshiba
    120 GB hhd 1GB ram
    15.4-inch TFT
Fastboy42
Banned
Restart the computer and press whatever button it says to get into the bios (it should say somewhere).then look through the tabs and you should see an option for touchpad enable or disable.
I hope that helps, thats about the best explanation i can give off the top of my head.
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
lordbob75
Lord of Bobs
Vista Pro
Yeah that is a good explination. Congrats on PowerUser by the way.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
