Transparent Square over Icons
BigTam
9
Location
England
Greetings!
Is there a wat of removing the transparent square that appears around an icon when rolled over?
Thanks :geek:
    P4 3GHZ
    Gigabyte
    2gb DDR3200
    nVidia5200
    External 360GB
    Internals x3
    120GB
    129GB
    200GB
Archpope
Power User
22
Location
Orange County
Depends on whether your computer is set to execute program icons with a single-click or double-click. I noticed Sony likes to set up their computers that way for some reason. Under "Folder Options," set it to double-click and that should get rid of it.
BigTam
9
Location
England
Know what you mean Archpope.. Mine is setup for double click but when you hover over an icon on the desktop it will display a boundry box around the icon.
    P4 3GHZ
    Gigabyte
    2gb DDR3200
    nVidia5200
    External 360GB
    Internals x3
    120GB
    129GB
    200GB
BigTam
9
Location
England
Maybe not without turning off the entire section of transparency..
    P4 3GHZ
    Gigabyte
    2gb DDR3200
    nVidia5200
    External 360GB
    Internals x3
    120GB
    129GB
    200GB
Bare Foot Kid
R.I.P. August 13th 2014
2,616
Location
The Lowcountry
Hi BigTam
I'm not sure if this is what you are asking!
Try clicking on an empty spot on the desktop?
That should at least make the transparency go away.
I don't keep things on my desktop, so I don't
have much experience with it.
I hope this helps!
Later Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
BigTam
9
Location
England
#8
Thanks guys. I had a feeling on that being the only solution Brink.
Great forum too - Well done!
    P4 3GHZ
    Gigabyte
    2gb DDR3200
    nVidia5200
    External 360GB
    Internals x3
    120GB
    129GB
    200GB
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#9
Your welcome BigTam. Wish we had a better solution for you.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
1
#10
I am using the classic folder views so this may not pertain to you but going to your folder options then to view, the second to last setting is what turned this on and off for me.
"Use check boxes to select items." I had clicked this on for some reason and the little squares just got on my nerves. I went back to folder options based on the discussion here and found the setting and clicked it off. Now I am back to my regular viewing. Hope this was helpful.
