Trouble connecting to websites in IE
sygnus21
Here to learn
Has anyone else had trouble connecting to certain internets sites they otherwise could visit before Microsoft issued their emergency security patch about two weeks ago? Solution(s)?
After patching my system, I’ve found that I can’t connect to, or have limited functionality on certain websites, last.fm.com comes to mind; I couldn’t listen to one of the music liberties there till I turned off Internet Explorer’s “Protected Mode”. I’m using the 32-bit version of IE.
When it comes to IE’s security features and settings I have to admit I’m clueless.
Other then suggesting I switch browsers, yeah, I know, IE “blows” :rolleyes:, are there some settings in IE that I should look at.
Thanks
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
mansrm81
Sorry I don't know cause I don't use IE7 anymore.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
NormCameron
Thanks
As part of the IE "fix" they recommend you turn your internet settings in the Tools Menu to "High"
This would severely curtail your browsing experience. Also if your internet settings disable Java or ActivX controls this could also affect the websites you visit. You should be aware that Java and ActivX are also used by the "baddies" to download malware to your computer so use them with caution and make sure you have a good antivirus and regularly scan for spyware and malware using the free Microsoft MSRT (among others)
Norm
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
sygnus21
Here to learn
Anti-Virus - Check
Spyware/malware scanner - check
Phising Filter on in IE - check
I don't have my internet settngs set to "High" as I do know that'll kill my browsing experience. Whatever Microsoft did with this patch seems to have curtailed my browsing experience as well. Guess i'll have to look as my active x controls and java settings and figure out what's what.
I generally shy away from suspicious sites, am aware of the java and active x attacks posed by the bad guys.
Thanks.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
