Trouble with typing keys
Lamichele
All the typing keyes stick on this Laptop can anyone tell me how can I fix this problem, keyes sticking are the Del, the enter key and all the cursor keyes. everything on the far right of the key pad.
chaosrealm93
Power User
Re: Trouble with typing keyes
did you ever spill anything on your laptop? if its juice or the like, it may cause the keys to stick. if its just sticking without a reason, then you may want to try contacting the manufacturer for replacement keys and the mechanism that goes underneath. im guessing your laptop uses scissor keys.
    AMD Phenom ii 940 - 3.60GHz
    ASUS M3A79-T Deluxe
    Kingston HyperX 2x2GB 1066MHz 4096MB
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Western Digital Caviar Black 1TB 7200rpm
    Corsair AX850
    Coolermaster HAF 932
    Scythe Mugen 2 rev.b
    Logitech G500
    Das Keyboard Silent Professional
    iunno.
Lorien
Account Suspended
Hi Lamichele,
Welcome to Vista Forums!
Chaosrealm93 has pretty much covered the situation. This sounds very much like the result of a spill of some sort (or even crumbs dropping in if you were eating over the computer and mostly on that side or possibly dust or particles getting in depending on the environment where it is used).
What is the manufacturer, make, and precise and complete model of the computer? I'd like to examine the troubleshooting guidelines and also see how complicated it is to remove and "clean" out the keyboard with a can of air (or other options if they provide them) to see if that works before spending money on a repair or replacement (and to see if you can just order the part and do the exchange yourself, thus saving time and money).
If you're having trouble with that many keys, then I recommend you replace the entire keyboard (including the keys as well as the keyboard base) rather than try to do it key-by-key - it will be simpler and probably cheaper as well. I'm not even sure the manufacturer will give you a choice anyway.
I'm convinced this is NOT a software problem or that it has anything to do with Vista or anything you installed. This seems to be entirely a hardware issue. If you know someone with a USB keyboard you can borrow, give it a try and see if it has the same trouble - I'll bet it works fine. If it does have the same problem, then post back as that would be quite surprising and the problem may lie elsewhere (though I'm not sure where that could be at this point).
I hope this helps.
Good luck!
    1920 x 1200 pixels
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
Lamichele
Thank you for your quick reply, I have asked the other members of the family and from what I was told nothing was spilled on the key board and no one ate when using it but again thank you for trrying to help.
richc46
If it is the entire keyboard, I feel that a new keyboard is needed.
There may, however, be a way to adjust key sensitivity for your specific keyboard.
