Trouble with Vista Voice Recognition and MFC-based app.
vistauserX1
I have an MFC-based application that i'm trying to use with Vista's built in voice recognition feature. The platform that the application has been built with is Visual Studio 2005, using Windows XP.
I have a simple textbox, of MFC type CEdit, that i'm using to extract the output text provided by Vista Voice Recognition. However, the results are not so good. After speaking a sentence using VR(for example, "this is a test"), the results i receive from the event handler of my CEdit textbox is "thi" and then "s". In other words, for a word of length x i get the first x-1 letters of the very first word, and then the last letter of that word, and then all other words get omitted. I do not run into this problem when using other kinds of voice recognition software, such as Dragon.
Should i be using a different type of MFC structure? Is there a special SDK i'm supposed to be using to get this to work correctly for Vista?
MilesAhead
Eclectician
I would ask on MSDN since it's MS sw development using VS tools.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
vistauserX1
Well, maybe you could answer this...how exactly does Vista VR output the text? One character at a time, or in words? I've seen it work fine using notepad, but i would certainly be curious as to how the output is being done exactly.
