Trying to convert a RAID installation to an AHCI one
I'm trying to change my Windows Vista (installed as the boot disc originally on a RAID config) to AHCI, but even after I change the two entries in the Registry Editor to '0' for both AHCI and RAID drivers, Vista fails to load when I change the config to AHCI for SATA. Any suggestions?
Yard Dog
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    Acer E181H ([email protected]) 128MB GeForce 6150SE nForce 430 (
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Yard Dog
LOL, that is too funny, let me see what else i can hunt up.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Alright, thanks. Appreciate it Yard Dog. Looking forward to your reply.
I was wondering if there was a possible way I could manually install an AHCI driver to my Vista installation, but Google doesn't seem to be giving me any links to instructions for that.
Yard Dog
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Yard Dog
What make and model computer are you using ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
If you're talking about the motherboard, it's unfortunately a Gateway-branded stock. I don't even know exactly what the (original) make and model of the computer is. Here's a generic specification list on the Gateway website for my line of desktops:
Gateway Support - Specifications
I tried installing the HDD into my newer computer (with AHCI mode on) to see if it would boot there (incase my stock Gateway's mobo was having issues), but it seems to give the same issue. It starts to load Windows, then fails, BSoD's, and restarts. The exact same.
So I can assert that it's not a motherboard issue.
