tsst corp cd/dvdw ts-l632d ata device
1
Help!! My device driver for my cd/dvd-rom has stopped working. When I go to device manager, there is a yellow exclamation point next to it. It was working perfectly fine a week ago. I have checked for solutions and possible driver updates to no avail. If someone could tell me what I can do to fix this problem, it would be greatly appreciated. Please make sure that it is in a simple, step-by-step format. I'm still learning about computers. Thanks. :confused:
2
I'm currently experiencing the same problem. I'm on an Inspiron E1505 laptop with Vista Home Premium 32bit installed. I did what Raj said about uninstalling the driver (the one with the yellow ! by it), and then restarted my computer. However, upon the computer restarting, it attempted to reinstall the driver but instead I got a "Device driver software was not successfully installed." (For the record, the driver I need is TSSTcorp DVD+-RW TS-L632D ATA Device.)
I've tried installing drivers for it by other means, too, but whenever I run the .exe program, it says "Drivers not found!!" or something to that effect.
Any other advice?
tanuj_chadha
Devil
316
Location
India
You can download the drivers for your drive from here:
Drivers and Downloads
OR
Download & run merge the following file to the registry. Make sure that you save the file on the desktop & then merge it.
    T4200 Intel
    2 X 1GB DDR2
    Intel Integrated
    1 X 250GB 7200RPM
2
Holy crap, it actually worked! The second one, that is. (The driver that you gave me was doing the same thing as before -- only popping up with a "Drive not found!!" message and then not doing anything.) But the file I merged actually worked! Wow!
Thank you so much! You just saved me a lot of hassle! ♥
1
I'm having the same problems on a toshiba a200 1da with the drive mentioned. the uninstall and restart didn't work, and nor did the driver from the tsst website. i haven't a clue what to do, and I may have to resort to paying to get it fixed. any other ideas
tanuj_chadha
Devil
316
Location
India
#8
Did u run the cdgone.reg file & then see if the issue was there or not. If still the issue persists then try booting through the windows vista dvd. And we can check if the hardware is functional or not.
    T4200 Intel
    2 X 1GB DDR2
    Intel Integrated
    1 X 250GB 7200RPM
44
#10
    Intel i7 920
    Intel DX58SO
    6GB PC3 12800 DDR3
    Asus 9800GTX+ 512MB
    AOC 917Vx
    1 TB Western Digital Cavair Black
    320GB Seagate Barracuda
    250GB Western Digital My Passport
    Antec EA650 650W ATX12V
    Antec Nine Hundred Black Steel ATX Mid Tower
    20MB down / 5MB up (Fios)
silver56
1
#11
I have a Gateway TSST corp TS-L632H cd/dvd giving me the burn disc error 2131 in Itunes which is a new error for me. I ran driver check and it said the most current. I uninstalled the drive, powered off. Powered back on and it reinstalled the drive - BUT SAME ERROR. Any ideas? :huh:
2
Location
Ohio
#13
ok i am having the same issues as the others :-(....i have tried restarting after uninstalling have tried what tanuj_chadha but none of it works :-( i really dont want to have to reboot with the windows disk and i think i did what tanuj_chadha said the right way can any of yall help me :cry:
    HP Pavilion dv6000
    Genuine Intel(R) CPU T2060 @ 1.60GHz
    2549 MB
    Mobile Intel(R) 945 Express Chipset Family
    Model: ST9120821AS ATA Device
2
#14
I am having a similar issue with my tsst corp cd/dvdw ts-L632m ata device. I have an hp dv2601tx notebook and it has stop reading dvds. It still reads cds. I have reinstalled the drivers yet still it doesnt work. Cna anyone assit?
    hp pavilion dv2601tx
    hitachi 240 g
    intel r core (tm)2 duo cpu t7500 @2.2 ghz
    4 gig
    nvidia nb8m-gs
Swannie12
1
#15
Did you by any chance install iTunes on your pc? My device stopped working after installing iTunes, and nothing I tried worked. I simply uninstalled iTunes, and things were back to normal automatically - device working as before.
Maybe it might work for you too! Good luck.
2
Location
Ohio
#16
i did have itunes intalled then uninstalled it and thats when my problems started.....now to get my disk drive to work i have to restart my computer each time i put a disk in for it to read it
    HP Pavilion dv6000
    2549 MB
twiggyN1
8
#17
im having a problem with my disc tray not reading anything or opening up except i can open it up manually and that is it. i had my own thread but i have recieved no help on it but i guess this is the thread its being discussed in i tried what you suggested in the first page but it didnt do anything for me i would like some help on this situation please and thanks for your time.
tanuj_chadha
Devil
316
Location
India
#18
Try to go in the system BIOS & check if the tray would open up or not. Try to re-seat the drive cable once & then try. If that also fails try to update the firmware of the drive.
    T4200 Intel
    2 X 1GB DDR2
    Intel Integrated
    1 X 250GB 7200RPM
tanuj_chadha
Devil
316
Location
India
#20
When you start the system up or power on the system start hitting the F2 or Del key on the keyboard. And you are in the BIOS. Then try to open the cd drive using the button.
    T4200 Intel
    2 X 1GB DDR2
    Intel Integrated
    1 X 250GB 7200RPM
