Solved tsst corp dvd+-rw ts-l632h wont recognize discs
dudezilla
Banned
I am having a problem with my tsst corp dvd+-rw ts-l632h recognizing discs.
I have tryed to go to the DELL websight and update the driver, but was not able to
get it to install. I have also tryed using the DRIVER MAX
program with no luck. when i put a disc in the drive, I can hear it spinning,
but get the message "please insert disc. Can anyone please advise??? Maybe
I just need a new drive. It is in a DELL inspiron 1525
    DELL inspiron 1525
    Intel Premium dual cpu t3400 @ 2.16GHz 2.17GHZ
Lottiemansion
Does the PC drive play a purchased DVD or music cd? If not, you will need a new drive! OK?
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
dudezilla
Banned
yeah, I think I need a new drive. I noticed that the eye never moves. thanks for your help.
    DELL inspiron 1525
tanuj_chadha
Devil
You can try the following steps:
1) Try to boot from the OS media or the Dell Resource CD (Drivers Cd) - If the system is able to boot then the CD drive is working good.
2) In case you are able to boot then run the file from the following link:
http://gur.in/registry/cdgone.reg
    T4200 Intel
    2 X 1GB DDR2
    Intel Integrated
    1 X 250GB 7200RPM
Jet944
I am having this same issue, but my drive will recognize regular discs. Only blank discs aren't being read.
I've been trying everything I can find listed around here, including attempting to update the driver (it just said no updates available), uninstalling the CD/DVD driver and restarting (also after taking out the filter values or whatever it was called...), and downloading the FrogASPI. It still won't read blank discs.
    Dell Inspiron 1525
