TSSTCorp CDDVDW TS-L632H ATA Driver problem error code 19
Kezwick
Hi
I am wondering if anyone can help me, I have this error on my cd/dvd driver & I am not sure how to sort it: Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
I am quite new to this, I have uninstalled the driver & searched for new drivers but it just tells me that it hasn't installed it properly.
If I put a CD in it starts to read it then stops & nothing happens. I have searched the net & tried to find a solution myself but nothing as yet.
I'd appreciate it if anyone could help me, but the simpler the better please.
Thanks a lot
K
pooch
Old Dog
Hi Keswick,
Welcome to the forum
There are a lot of problems with this drive
Is your laptop still under warranty? If so take it back to the dealer
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Drive #1 - SAMSUNG HD252HJ (250 GB)
    Drive #2 - Hitachi HDT721010SLA360 (1000 GB)
    Drive #3 - SAMSUNG HD250HJ (250 GB)
    Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
    I have also used Fedora, Suse, Ubuntu Linux
    And all other Windows from 95 to date except ME
Flavius
Expelled
Hi Keswick,
Pooch
It's true there are a lot of problems with this drive but untill now I can't see any reason he should take it back to the dealer.Error 19 is mostly accidents repearable
Official MS link:You can no longer access the CD drive or the DVD drive, or you receive an error message after you remove a CD recording program or a DVD recording program in Windows XP: "error code 31"
Our forum:http://www.vistax64.com/tutorials/201659-dvd-drive-icon-disappeared-computer-fix.html
mikeargent
i have had a c19 twice now every time you shut down uninstall the driver each time you start you will get an error "could not install software correctly code 19"
if you keep uninstalling adn allow it to re-install each time evetually it will install ok.
the first time it was about 15 restarts and about the same the second time.
