TsstCorp CDDvdw Ts-L633b ata device
Edy
My dvd player will no longer work. It just quit! Does anyone have info on this problem and how it can be solved?
smarteyeball
Eye know, eye know
Check in device manager under DVD/CD-ROM drives and see if it is either still showing or displaying a yellow triangle.
Did you apply any Windows Updates before it stopped working?
Attempted to flash the DVD firmware?
Was it showing any signs of faulty behavior prior to it stopping? (increasing noise, longer than normal operation time, not reading or burning correctly)
If it's not software related, sometimes DVD players just up and die.
