Two Firewalls?
Fred44
I was just reading the Security chapter in the "Tweaker's Guide Tweakers Companion for Vista" and the author says it's not a good idea to use 2 firewalls simulatneously. I've read conflicting opinions on this. I have my Windows firewall and the McAfee firewall both enabled and it hasn't caused any noticable problems. Can the two firewalls interfere with each other and somehow diminish your level of security? Should I use just the Windows firewall?
Fred
    HPs3700y Slimline
    AMD Athlon64 X2 (B) 50000+ 2.6 GHz (65W)
    Asus M2N61-AR
    3 GB
    NVDIA GeForce 6150SE nForce 430 (Integrated on motherboard)
    High Definition 6-channel audio ALC 888S chipset
    SAMSUNG SYNCMASTER 914V FLAT PANEL LCD
    1280 X 1024
    320GB SATA 3G (3.0 Gb/sec)
    160W
    HP
    Logitech Marble Mouse
    Broadband Cable Connection (256 Kpbs?)
    Not sure what case or cooling means. Could not find in any documentation. The keyboard is the standard that comes with the HP Slimline.
Yes...two firewalls can fight each other and create a bigger security risk than having one firewall alone. You should only use one firewall at a time unless its a front-end and a back-end firewall protecting something like a network. But never have two firewalls on a stand-alone as its not really a good idea :)
    Hewlett Packard
    3.40Ghz / 2.20Gz Duo Core
    2GB / 3GB
    160 GB / 160 GB
I might be wrong, but I think two third party firewalls will mainly cause conflict. The Windows firewall just "sits back" while you run McAfee. I've never had any conflicts or problems running Windows Firewal and Comodo Firewall.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
I think windows firewall can cause conflicts...its still a firewall. In the security center it says under it two firewalls running together can conflict. It doesn't say that windows firewall is exempt. However maybe your right EverLong18, but if COMODO is protecting your computer anyway why take the chance that your creating a security hole?
If you were really worried about a hacker to have 2 firewalls...install about 3 and keep disabling 2 and enabling the third. It will be very hard for a hacker to get enough time to find a vulnerability to penitrate it before you switch.
    Hewlett Packard
    2GB / 3GB
    160 GB / 160 GB
Any opinions on which I should use? I just disabled the Mcafee.
    HPs3700y Slimline
    Asus M2N61-AR
    3 GB
    1280 X 1024
    160W
    HP
Well I use COMODO as well as EverLong18 so im guessing its not bad ;).
I also had issues with McAfee...it was blocking port 443. What kind of stupid firewall does that?
    Hewlett Packard
    2GB / 3GB
    160 GB / 160 GB
The idea of running multiple firewalls itself is not a problem.
In theory it can work, and back in my old days when I was very adamant about computer security I ran FOUR consequitive firewalls at the SAME TIME without issue or even noticable lag on internet connection.
I also ran lots of security tests on sites (that try to probe/access your computer and then give you the results of what they could/couldnt do) and it turned out that my 4x firewall combo worked against EVERYTHING those sites could throw at me.
Ofcourse I said 'in theory' because it is always possible certain firewalls will conflict with eachother.
The firewalls I used back then btw were: windows firewall, Sygate personal firewall pro, zonealarm pro and F-secure.
    Me, myself and I
    Intel Core 2 Duo E 8500
    Asus P5Q3 DELUXE
    4x 1GB DDR3
    Asus GeForce 9800GTX+
    SoundBlaster X-Fi X-treme gamer
    Samsung Syncmaster 226BW
    1680 x 1050
    1x 250gb SATA
    4x 1TB SATA in RAID5
    CoolerMaster 650Watt
    CoolerMaster 690
    4x 140mm, 3x 120mm, 1x 80mm casefans
    Razer Lycosa
    Logitech G5
    ADSL 12mbit/s
    My other OS is a Linux =)
... :huh:
    Hewlett Packard
    2GB / 3GB
    160 GB / 160 GB
what's that supposed to mean Fmjc001?... you mocking me? :P
    Me, myself and I
    Asus P5Q3 DELUXE
    4x 1GB DDR3
    1680 x 1050
    1x 250gb SATA
    CoolerMaster 690
    Razer Lycosa
    Logitech G5
    ADSL 12mbit/s
It means why the hell would you need 4 firewalls :p
I'm shocked they didn't try to kill each other to be honest :geek:
    Hewlett Packard
    2GB / 3GB
    160 GB / 160 GB
well, back then I was a security junkie. I ran every piece of security software I could on my computer... god knows why.
Nowadays it seems I'm the complete opposite, having only windows firewall to defend me from the harsh world of TEH INTERWEB. no AV, no other firewalls, no nothing =D
But yes surprisingly enough all 4 firewalls ran perfectly fine.
Funny thing was when I would launch a new online application (like a game) I would get a popupwindow from firewall Nr1 asking me to allow/block it, and after I pressed allow id get a popupwindow from firewall nr2 asking the same thing etc etc ^^
Was quite funny to see to be honest
    Me, myself and I
    Asus P5Q3 DELUXE
    4x 1GB DDR3
    1680 x 1050
    1x 250gb SATA
    CoolerMaster 690
    Razer Lycosa
    Logitech G5
    ADSL 12mbit/s
It is not advisable to run more than one SOFTWARE firewall at a time, which is what most people do. What many people don't realise is that if they are using a router, they will already be using 2 firewalls since most routers already have one built-in to the hardware. However, because this is self-contained on the router, it cannot conflict with the software version on the PC.
The problem with running more than one SOFTWARE firewall is not so much conflict (as is the case with AV software), rather it leaves your system open to attack. This is because communication over the Internet is done via ports, which can be open (access) or closed (no access). This is automatically carried out by most firewalls, and can also be manually configured. Here lies the rub. If you are using multiple firewalls, and you forget to ensure that they are all set identically, i.e. leave a port open on one which is closed on the others, then you can end up with a leak.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
